#11 |
You should try running the Haibec chip with a colder set of plugs. 1 heat range may make all the difference. If the problem is tip in fuel, you could take a look at the fuel pressure when it happens, it may not be increasing as it should. These 2 things were problems for me when I first got my ZR1. Goodluck, nothing is more annoying than a problem at WOT.
#12 |
The problem only happend at low speed and medium speed....
When I hammer down...it seems to be fine...of course it is so loud, I could not hear the knock |
#13 |
Ahhhhh, then the solution is simple, just stay at WOT throughout your entire driving experience. Goodluck with the fix.
#14 | |
That is pretty much what Marc said.....drive it like I stole it...because the previous owner didn't |
#15 |
![]() Join Date: Dec 2005
I just put in a Haibeck chip 1 week ago and its great; can feel the difference. Still using stock plugs and at 17500 miles.
For what its worth. |
#16 |
![]() Join Date: May 2007
LowFlight, Did you ever get a scan done on your engine to get a positive verification that you are getting knock? I have scanned mine and my I get a lot of knock spark retard events. I am trying to isolate the problem to something that I can fix or tune out.
Thanks, Jim |
#17 | |
![]() Join Date: Aug 2006
#18 | |
