Old 07-11-2007   #11
Default Re: rear window drain
Originally Posted by Aurora40
I put one on my '87 and thought it was a real POS. I got the Mid America kind that came with the drill bit. Well the brass part didn't sit flush, and the lip was so high lots of water didn't drain. Much of what did drain drained between the hose and the body, not through the hose.
But maybe I just sucked at installing it. I just found most of that mid america stuff like the drains and such to be junk.
The brass washer does require a bit of massaging to optimize the fit to the contours present. I just put it in, took a punch and a few light taps with a hammer and matched the contour. I put a little RTV under the washer when I installed it for good & wiped it smooth after putting a little pressure on it.
A26B is online now   Reply With Quote
Old 07-12-2007   #12
QB93Z
QB93Z's Avatar
I have the drains on the Z, they work great.
