Old 12-04-2024   #11
scorp508
Default Re: DRM custom FX3 controller. Anyone remember these?
Originally Posted by grahambehan View Post
Here is what I have
Holy moly, Graham! Thanks for digging that out. Now I want to find a few, see if I can pull the code off, and compare the differences.
Old 12-05-2024   #12
tpr60
I have one I bought many years ago, note on it says Road Atlanta race track. Never used it.
tpr60 is offline   Reply With Quote
Old 12-05-2024   #13
scorp508
Talking Re: DRM custom FX3 controller. Anyone remember these?
tpr60, i think you and phrogs should open them up and see what it says on the chip. For science!
The lid pops off relatively easy with small tabs around the perimeter, then two screws next to the connector. Once the screws are out, then pull the two larger black screw tabs away from the plastic body slightly while the main board facing down. The board will fall out enough where you can then remove it.
I love the old Compuserve address.
Old 12-06-2024   #14
rkreigh
still have drm fx3 and set for full soft and hard rwar
good enough for 11.27 on drag radials
switched to coil overs so I don't use it
Old 12-06-2024   #15
dredgeguy
dredgeguy's Avatar
Ron, sent you a PM
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 12-10-2024   #16
phrogs
phrogs's Avatar
Originally Posted by scorp508 View Post
Feel like opening it up to see which chip is in it?
I will need to find it first haha when I do Ill post some photos.
JOHNNY P
Currently own
Old 12-13-2024   #17
tpr60
Just dug up the modified shock controler, it has a Bilstein sticker on the outside AK2100, inside chip has a pice of tape with code BB206A written in pen. Masking tape on the outside says "used Road Atlanta '94 performance modified by Bilstein". Also have the shocks that came with the contriller.
