Old 10-07-2024   #11
KJL
Default Re: starter rebuild kit
Originally Posted by Young1 View Post
File the contacts to remove carbon deposits. I even use a die grinder stone on my battery drill to shine them up. The starters seem to require it at 30-40k miles of use.
Just hit 30. I also read where the battery terminal on starter must not be rotated. Apparently there is no mechanism to prevent this from happening when tightening the terminal nut so one must be aware of this when torquing. I have had the starter out of the car and don?t recall paying much attention to this when re-installing. Thought maybe if it wasn?t supposed to turn it wouldn?t but I give the GM engineers maybe too much credit.
1995 ZR1 #159
1992 ZR1 #280
1996 Collectors LT4 (Stock)
572 rwhp
Old 10-07-2024   #12
Young1
Young1's Avatar
Different starter design than a SBC. Contact is L shaped. Yes I did rotate them on SBC back when young and broke in 70?s and 80?s. No longer young and no longer broke but yet fix stuff rather than replace it.
Steve Young
Second Owner
SOLD
SOLD
Old 10-08-2024   #13
WVZR-1
What is the OAL(Overall Length) of the thought to be correct plunger? Anyone have one 'in hand' that they can measure?
