03-25-2024 | #11 |
Re: Oil leak
I checked both those areas, as well as others, very carefully. All dry. I could see evidence of oil on the bottom of the header flange for cylinders 2 and 4. Top of the header flange is dry. With a good light, I can see where the oil sheen starts. I thought maybe the timing chain tensioner cover, but that was dry also. Only leaks when engine is running. May also explain why I need to add coolant every few hundred miles.
The engine is a Haibeck 415. Sent from my Pixel 4a (5G) using ZR-1 Net Registry mobile app
1992 ZR1 #442, 2 tops, White, White, Haibeck 415, 3.90 gear, Coilovers 2018 Audi RS5, 2.9 V6 Twin Turbo, Auto, Black, Black 2021 Audi Q3, 2.0T, 8 spd Tiptronic, Navarro Blue metallic, Pearl Beige |
03-25-2024 | #12 | |
Re: Oil leak
03-26-2024 | #13 | |
Re: Oil leak
