Old 06-11-2007   #11
ROGER E
Default Re: fuel injectors
Uh oh. Please don't tell me I installed the wrong ones. I got the part number from posting in this thread:
http://zr1netregistry.com/forum/show...ghlight=150821
To make matters worse my engine is a 91 with 94 heads. It runs great but if there's room for improvment please do tell!
ROGER E is offline   Reply With Quote
Old 06-11-2007   #12
mrzzzr1
mrzzzr1's Avatar
Wink Re: fuel injectors
Kurt White "White Racing" states R/C injectors are as good as it gets. I got mine for $68 each from R/C direct in Ca. Had to buy 8 primary o-ring seals that were not included and they were very pricey through a Buick Dealer my mechanic deals with. I suggest looking elsewhere for the seals.
1990 Red on Red
vin #2433
mrzzzr1 is offline   Reply With Quote
Old 06-12-2007   #13
swaindm
Red face Re: fuel injectors
150821 is correct! I was confusing some non stock applications. Sorry!! DMS
swaindm is offline   Reply With Quote
Old 06-13-2007   #14
ROGER E
Cool!
Old 06-16-2007   #15
ffvetteman
Whew you guys got me nervous for a minute there!!! I got 16 150121's sitting on the table in front of me ready to go in.
This week I hope Just need to get a hold of a set of spark plug wires now.
ffvetteman is offline   Reply With Quote
Old 07-14-2007   #16
george henry
george henry's Avatar
Thumbs up Re: fuel injectors
Hello. Just replaced all 16 injectors with Accel part number 150121 from Atlantic Speed for about $500. This took care of my high idle problem as well as a bad lack of power (bad stumble when the secondaries kick in), also replaced the PCV hose with the unit from White Racing and got new PCV valves. The old hose was a loose fit to the valves and this probably contributed to the high idle (1200 rpm), it now goes right to 750 rpm after start. The injectors were the originals and ethanol had taken its toll on them. I was a first timer on the plenum removal, it's not that big of a deal.
1990 #1507
1990 #1507 Black/Grey/flowmaster-DRM chip
george henry is offline   Reply With Quote
Old 07-14-2007   #17
george henry
1990 #1507
Old 07-15-2007   #18
zr-1assassin
zr-1assassin's Avatar
there is a new set on ebay with both pcv's!
zr-1assassin is offline   Reply With Quote
Old 07-15-2007   #19
george henry
Just read Roger E's post about using the outer slot on the injector for the clip to the fuel rail (the slot next to the o-ring?) I just pushed them into the rail and used the slots that look like they were made for the clip. There were no leaks and it runs fine. Does anybody know how much difference this makes? Should I worry?
Old 07-15-2007   #20
Jagdpanzer
Jagdpanzer's Avatar
So do the Accel 150121 injectors work in both the 375 and 405 hp LT5 engines?
