Old 07-25-2023   #11
Subfixer
Subfixer's Avatar
Default Re: Carlisle 2023 - Soliciting Demonstration Topics
I vote for Tech 1 training. I'll have to remember to bring mine.
Sent from my Pixel 4a (5G) using ZR-1 Net Registry mobile app
2021 Audi RS5, 2.9 V6 Twin Turbo, Auto, Black, Black
Old 07-27-2023   #12
Mystic ZR-1
Mystic ZR-1's Avatar
I'll remind ya...😀
Old 07-27-2023   #13
RICKYRJ1
RICKYRJ1's Avatar
I need a driverside outside window sweep installed, I Have ABS and ASR lights on and I have a complete 4:10 rear batwing and all (Thanks to DR. Phil) that needs to be swapped in to replace my 3:73 set up, and I need the oil changed lol. Car has 19k miles so its all clean work lol, Not sure if any of it fits your criteria but I appreciate the consideration Ill be there on Friday but wont have my car there till Saturday Look forward to seeing everyone regardless of what gets done or not.
Old 07-28-2023   #14
dredgeguy
dredgeguy's Avatar
Sounds like you need a Wazoo maintenance day. We could do the rear swap, clear/fix the codes and do the window sweep...you get the pizza
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 07-29-2023   #15
RICKYRJ1
RICKYRJ1's Avatar
Yes Sir! let me know when works best for the Brothers WAZOO
Old 07-30-2023   #16
Corvette95
Corvette95's Avatar
I would like to see hood adjusted to front doors and front bumper and to get the correct gaps while opening and closing the hood works as should (ie. no one or both sides not closing or one or both latches not releasing.) . I have one that could use some fine tuning.
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 07-31-2023   #17
dredgeguy
dredgeguy's Avatar
I know that the Tech 1A is hard to find and while we sure need training to use it to it's full potential, sure that others have other scanners that work as well. Marty from Contes, I believe Lewis uses another scanner. Have him bring it and show an alternative?
Charlie
__________
Dredgeguy
Dana 4:10 gears
Old 07-31-2023   #18
98indypacer
I have a Mastertech 3100 that actually takes the Tech 1 cartridge. I also have a Bosch OBD1300 which is a newer product but unfortunately recently discontinued by Bosch. You can still find them on eBay for a reasonable price. What does Lewis use?
98indypacer is offline   Reply With Quote
Old 07-31-2023   #19
dredgeguy
dredgeguy's Avatar
I had taken note of what Lewis uses but can't put my hands on it. Perhaps Marty/Lewis will post up?
Charlie
__________
Dredgeguy
Dana 4:10 gears
Old 08-06-2023   #20
Raykahn
Raykahn's Avatar
I recently confirmed I have a small leak in one of my refrigerant lines.
A small section of plastic tubing needs to be replaced (or patched? its small so either probably would work). Maybe the more useful bit of that process for everyone would be draining/recharging the refrigerant. I was going to wait until a larger maintenance item came along (or the next WAZOO day) before bothering with it. Honestly a small piece of FlexTape would probably stop it outright.
So potential 4 items from that:
  1. Patching a line
  2. Replacing a line
  3. draining
  4. recharging
Raykahn is offline   Reply With Quote
