Old 09-26-2022   #11
secondchance
Default Re: Air filter fitment
Originally Posted by efnfast View Post
My filter measures correct, yet the hole in the plastic air box, from the raised edge measures 9 3/8th by 16. How can that be? The mounting flange (the raised edge) is no longer flat, like it's heat distorted.
Holly s**t Steve, you seem to have an incredible shrinking air box!
Old 09-27-2022   #12
efnfast
Right? Might be time to call Mark at Mirrock.
Old 09-30-2022   #13
I can't even get the cover on.
The Air Filter Installation
The outside filter gasket (part of the filter) that fits into the cover is.....
17-3/8" by 10-5/8" outside dimensions and inside dimensions of the cover.....
The Air Filter fits up into the Cover.......not down into the Air Filter Housing.
A. K&N 33-2035 High Flow Air Filter
B. K&N 33-2035 High Flow Air Filter
This is for a 1990 ZR1 or 1995 ZR1....I assume for all ZR1s 1990 to 1995.
The Air Filter total height can be up to 1-1/2".
I show the Air Filter Housing, two ZR1 filters and the filter cover in the photo.
The 1990 Air Filter Housing has the hose connection on the Drivers side for the Air Injection Pump.
1. General Installation
There are three cap screws.....the Center Cap Screw is shorter than the other two on outside. The Center Cap Screw is inserted into the filter housing after the the filter is installed in the cover (Tighten the center Cap Screw before the complete filter housing is placed in front of the radiator). The Center Cap Screw screws into the filter housing only.
Make sure the five tabs are inserted into the filter cover. The five tabs are part of the filter housing (not the air filter).
The other two cap screws are inserted into the filter housing after the filter housing is placed in front of the radiator. Those two Cap Screws screw all the way into the radiator housing and are tightened after the complete filter housing is installed.
2. Connecting the Air Filter Housing to the Plenum
Lastly the Corrugated Flexible Air Connection between Filter Housing and engine Plenum air intake (Leave the Corrugated Flexible Air Connection connected to the Plenum Air Intake. The Filter Housing end of the Air Connection is slipped onto the Filter Housing before the Filter Housing is screwed into place with the two outside Filter Housing Cap Screws. The Air Corrugated Connection is tightened with a Band Clamp (Screw Band Clamp....use 7mm 1/4" socket with extension or flat head screw driver).
Post 276 - Air Filter Installation
3. Details for Installing the K&N Air Filter
Installing a K&N 33-2035 is a bit complicated for the simple reason K&N provides foam spacers that can be compressed to different thickness which should cover the alignment issues of the "Plastic" Air Box........but an Air Box that is not flat at the Air Filter Cover interface flat within 1/4" presents a problem when the interface is warped significantly more than 1/4". A NEW AIR BOX IS THEN REQUIRED unless the gaps between the box and Air Filter Cover can be filled with Silicon Seal or some other filler.
Use the provided K&N lubrication on the filter gasket (flat part) with the filter inserted into the Top Cover facing into the Top Cover. I then remove the filter from the Top Cover and set in place on the K&N foam gasket of the Filter Housing (which Foam Gasket is glued in place with Gorilla glue) if the foam gasket does not stick in place.
The "Trick" is to lubricate the Filter Gasket rubber facing the cap screws (towards rear of car). The Filter Top Cover is then positioned by inserting the five Tabs into the Top Cover (while keeping the Filter positioned on the Filter Housing). Then while keeping the five Tabs inserted, press down on the rear of the cover as it "slides" (the reason for the lubrication at that location) down in place on the filter as you tighten the middle front Cap Screw (THIS IS THE MOST DIFFICULT PART).
Documentation of the Installation of the K&N 33-2035 Air Filter.........It is a bit complicated to install a K&N 33-2305 Air Filter. These instructions come with the K&N 33-2035 Air Filter.....
Old 10-01-2022   #14
efnfast
I ordered one from Mirrock. We'll see when it arrives.
Old 10-08-2022   #15
efnfast
Got my new air box in. They are kinda a pain in the *** even when they fit properly. New one fits better. I think the heat distortion in mine was the culpret. The annoying factor might justify the SLP.
Then I was looking at my old one and decided to put it with all the rest of my 'Vette parts. What's on the shelf? You guessed it, an air box in good shape.
Old 10-08-2022   #16
secondchance
Not only me?!
Old 10-09-2022   #17
dredgeguy
dredgeguy's Avatar
Sounds like the Wazoo storage area at Jim's. Glad you got everything fixed up.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
