Old 09-05-2022   #11
HAWAIIZR-1's Avatar
Default Re: Jeal Carbon Fiber Intake
Originally Posted by JT ZR-Won View Post
Yep, that's the one... what a great looking design! When I looked up under the car, it seems the reversed air lid is the way to go
It a nice piece for sure. It seems like all of the possibilities do not do much for performance and mostly for looks, but this one I do like regardless. I know LocoBob ran some dyno testing on various air boxes with hardly any difference between them.
I agree with you about getting cooler air has to be beneficial compared to the stock design of sucking in hot engine compartment air.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 09-09-2022   #12
Thanks Craig I had not seen one of those before.
Old 09-09-2022   #13
Originally Posted by viper107 View Post
or the other one that looks aluminum is awsome too,id love one of those!!
For sure! I believe that was the one designed by Marc Coplan. I should have bought one of those way back in the day.
Post 34 - Stainless Steel Air Box and Air Filter (L98 and LT5)
L98
LT-5
Old 09-11-2022   #14
aafc
aafc's Avatar
I 'am using the stock air filter assembly warped in DEL cool tape with the hole
in front bumper from the A/O engineering. I also have the bubble warp
aluminum between the filter housing and radiator housing. It is not glued
down but sandwiched between them. That alone will help reduce hot air
reaching the lower side of the filter.
http://www.zr1.net/forum/picture.php...pictureid=3970
aafc is offline   Reply With Quote
Old 09-11-2022   #15
HAWAIIZR-1's Avatar
You are welcome Daryll. It is the only one that I like of our options.
BTW, my quest for the Cragar key was a bust after buying two possibilities. Thanks again for your help.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 09-11-2022   #16
HAWAIIZR-1's Avatar
That is some great ingenuity and anything to help the air to be cooler is a great improvement.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 09-13-2022   #17
aafc
aafc's Avatar
Here is the ZR-1 Splash front plate I modified to feed air into the stock air
filter housing. The hole in the front bumper was made for the A/O Engineering
cold air setup. I removed that and modified the opening to feed air straight
into the air filter. The ZR-1 Splash front plate was cut out to let air thru and
a black plastic screen installed to stop paper, small birds, etc from getting into
the filter. I still have a number of the ZR-1's Splash plate filler for the 1990
and 1991 thru 1995 for sale PM me for more information.
Old 09-15-2022   #18
HAWAIIZR-1's Avatar
Very cool! No pun intended. [emoji1360]🤙🏼
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
