Old 08-10-2022   #11
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Default Re: 1995 ZR1 Transmission Really Stiff...Sometimes
Originally Posted by DRM500RUBYZR-1 View Post
Something is amiss.
It should not be anywhere near as difficult as oyu have described.
Two suggestions.
First take it to a shop that will drain and refill the transmission with the correct lubricant. Mobil 1 or Amsoil are considered to be ideal for the ZF trans.
Second, make sure that your clutch fluid is both clean and more importantly full.
Once both of those have been done, if your effort is not greatly reduced then the transmission may have a mechanical issue.
That eliminates the simple easily correctable causes.
Good luck and keep us posted of your progress.
Marty
Check that clutch fluid level.
Marty
Old 08-10-2022   #12
Young1
Young1's Avatar
Flush out that forgotten black nasty clutch fluid. Drain and fill trans with this. B1EB5B41-AAC6-41D8-8C7A-DB5C101F192D.jpg
Mine noticibly shifted smoother after removing factory fill at 38k miles.
Steve Young
Second Owner
SOLD
SOLD
Old 08-11-2022   #13
Just for information.......I had a 91' Black Label Rebuilt by ZFdoc for my 95'.
He added a short shifter
It now shifts almost like an automatic
That is not a good comparison but you know what I mean
