07-19-2022 | #11 |
Re: Exhaust doubts
Thx guys, appreciate your input so far!
07-21-2022 | #12 |
Re: Exhaust doubts
Lots of options......if you want to minimize your cost then I say use a '96 LT4 car exhaust (2 3/4") and replace the resonator with an x pipe and swap on a set of headers. If no budget then b&b 3" with the adjustable muffler and a matching header.
07-22-2022 | #13 |
Re: Exhaust doubts
My car came with Billy Boat already on it and it sounds great. Downside is the drone in 6th gear is borderline unbearable.
Sounds like Corsa is the clear winner. |
07-22-2022 | #14 | |
Re: Exhaust doubts
My recommendation is whatever you do try to hear it in person and get a ride too if possible. Don?t go by video sound or what people tell you. I know that is difficult, but if the timing and opportunity is right, that is the best way. I almost pulled the trigger on a Corsa until I heard it in person. Many love it, but it?s not for me. I had my own put together (replaced resonator and mufflers) because of the lack of options. I didn?t see you mention SW. I?ve heard good things about Stainless Works system, but no first hand experience. https://stainlessworks.net/exhaust-1990-corvette/ Sent from my iPhone using ZR-1 Net Registry
07-23-2022 | #15 |
Re: Exhaust doubts
I have noticed a lot of folks mentioning drone with the B&B systems. My '90 has full length headers into a B&B system that sounds incredible, but has no drone sound at all. Are there different B&B systems out there?
A buddy of mine a long time ago had a '95 with a B&B system and I remember the drone sound he had at a very low RPM. Jay |
07-23-2022 | #16 |
Re: Exhaust doubts
The search for the perfect exhaust will never end. I've tried them all and settled on the 3 inch B&B Fusion system with the X-pipe. I upted out of the B&B mufflers with the dump valves integrated into them because it still causes a restriction and they run a old school vacuum operated set up.. So I Fabricated my own dump valves that come straight out of the rear pipes with no restrictions.. If it's not enhancing your performance you're just making noise......20220529_160810.jpg20220529_150933.jpg
The older I get the faster I was. |
07-23-2022 | #17 | |
Re: Exhaust doubts
Here is info from Marc: http://www.zr1specialist.com/HAT%20W...%20Systems.pdf Sent from my iPhone using ZR-1 Net Registry
08-11-2022 | #18 | |
Re: Exhaust doubts
Thx for sharing, love your setup. Question though - on slide 14 there are other headers, what type/brand are these?
Sorry for asking these questions, but in Europe there is not a lot of knowhow on this topic to collect for me. Rgds Mike Quote:
08-11-2022 | #19 |
Re: Exhaust doubts
Hi,
There is no budget constraint on this one. We are pulling the engine, so the right moment to upgrade from stock to something which really makes you feed and experience the LT-5. Which header would you match with the B&B 3? ? Rgds Mike |
08-12-2022 | #20 |
Re: Exhaust doubts
Hi Mike--Questions are always great to ask. Not sure we can always give the answers. I did not quite understand your note about "Slide 14". My '95 ZR-1 had a set of Stainless Works headers installed by Marc, no catalytic converters, and then it attached to the stock '95 exhaust system to which I afixed the cutouts in front of the rear mufflers. So he attached the SS headers directly to the stock exhaust. Hope that helps but if you have other questions please ask away. --Bob
2016 Long Beach Red Z06 #10281 "POPS Z" 1995 Polo Green #409 "WARP TEN"--Haibeck 350/510 package, 4.10s, Hurst, Stock Exhaust with QTP Cutouts --Sold but still running strong 1993 Quasar Blue #161 "HIL KING" --Sold but still running strong, now with more than 120,000 miles 1967 Marlboro Maroon/Saddle Corvette Coupe 300 hp/4-spd --Sold a long time ago ZR-1 Net Registry Founding Member #95 NCM Lifetime Member Favorite Quote--Attributed to Mickey Thompson: "Too Much Horsepower is Almost Enough" Last edited by WARP TEN; 08-13-2022 at 11:05 AM. |
