Old 03-03-2022   #11
Default Re: Clutch pedal travels too low
Originally Posted by Young1 View Post
I have the best luck to reverse bleed the clutch hydraulics to get all the air out of the slave. Ask them if they did that. Simple things first.
I'm not familair with the term "reverse bleed". What is that, zackly?
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 03-03-2022   #12
I have bled the clutches on both the Zs by drawing fluid into the system via the slave cylinder -exercising and coordinating the bleeder valve and slave's pushrod to pull in fresh fluid and purge air out of the system. (It's VERY quick and IMO much more efficient than pumping the clutch pedal dozens of times (and I've done it both ways & would never return to the pedal pumping routine...unless I'm on my bicycle!))
90 #1202
Sans secondaries
Old 03-03-2022   #13
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
My suggestion was based off of a slave cylinder issue from years ago. Bill B told me to try that. The system is self bleeding
If 50 does not raise the pedal, do it more.
We gave up at 70 once, went back and did it again and finally got a pedal that worked.
If it is a new clutch, pressure plate, throw out bearing clutch slave and clutch master, then odds still favor an hydraulic issue.
Try 150.
I have to accept that a tech at a GM dealership installed the hardware correctly.
They don't let the lube tech do clutch installs.
Good luck and continue to keep us posted of your results.
Marty
Old 03-03-2022   #14
Pushing fluid up through the slave.. i have a Phoenix Injector for that task
Old 03-03-2022   #15
viper107
viper107's Avatar
revearse bleeding gets the trapped air out of the bends(thats where the air gets stuck and wont bleed out)
95 admiral blue z(sold)/ / 93 ruby z(sold) 91 steel blue z/95 aqua z haibeck 510, 91 callaway 415 areobody #5
viper107 is offline   Reply With Quote
Old 03-04-2022   #16
Yeah, thanx! And, in conjunction w/ the '91-95 slave (bleeder on the bottom) I see how that tool would really be nice to purge the system.
Got pix?
90 #1202
Sans secondaries
Old 03-04-2022   #17
lfalzarano
Thanks Everyone! IT IS FIXED!!!!!
The solution was that when the mechanic replaced the origins clutch master cylinder, he left the original shims on the firewall. He removed the shims, installed the replacement, and bleed the system. The width of the shims were limiting the clutch master cylinder piston stroke!
Pedal feel is perfect and the shifts are smooth.
Thanks everyone for your suggestions that narrowed down the possibilities!
