Old 02-26-2022   #11
Corvette95
Corvette95's Avatar
Default Re: Engine no start after ECM put back in
Originally Posted by Jetjock View Post
What kind of damage could an x-ray do to an ECM? I do have SYS light and the check engine light on.
Roy
Probably none but I have heard about uv rays can erase or corrupt a PROM . I have not seen this in person and was read about online.
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 02-26-2022   #12
Jetjock
Jetjock's Avatar
Well, the first thing that I plan to do is check the fuel pumps as I did not hear them running when I turned the key to on. They are relatively new and always worked until I put the ECM back in. Then expand it out. I have a strong starter and electrical power from the battery so I can rule them out. We have been moving so its been difficult to work on it plus its been cold as blazes. Next week, I will be able to get into it. Thanks for your help. I didn't get any codes on the ECM so I'm pretty sure it's ok. I will call Haibeck Monday and discuss it when him. I don't have a Tech 2 so its old-fashion bloodhound checking to fix it. Thanks for the help.
Roy
Roy L. Carman
If I feel the need for speed,
I just think about flying the B-777.
1989 Dk Blue Coupe lost in divorce
1991 Black Coupe SOLD
1992 Black ZR-1 #423 SOLD!
1993 Ruby Red 40th Anniversary ZR-1 #334
1995 Black ZR-1 taken by ex-wife
2002 Pewter Coupe no idea where it is
2003 50th Anniversary Corvette #No idea what number SOLD!
ZR-1 Net Registry #516
Grand Sport Lifetime Member
NCM Lifetime #1468
ZR-1 Net Registry Board Secretary
Jetjock is offline   Reply With Quote
Old 02-27-2022   #13
Jetjock
Jetjock's Avatar
Okay today, I checked the fuses and they were all good. Next, I hooked up a pressure gauge to the Schrader valve and turned on the ignition. Nothing. So now I will go a little further and check the fuel pumps themselves. I put those pumps in 2019 and they were relatively new. They worked perfectly until now. I'll talk to Marc tomorrow about the problem.
Roy
Roy L. Carman
NCM Lifetime #1468
Old 02-28-2022   #14
Perry Mitchell
Did you remove the Schrader valve before connecting the fuel gauge?
Perry Mitchell is offline   Reply With Quote
Old 03-08-2022   #15
Jetjock
Jetjock's Avatar
Well, kinda have to to attach the the gauge. I've done this before.
Roy
Roy L. Carman
NCM Lifetime #1468
Old 03-10-2022   #16
Jetjock
Jetjock's Avatar
I tested the fuel pumps and nothing. I used direct and the fuel pump testing
connector. I could tell that the current was there by watching it spark. So both are dead probably locked up. I could hear something trying to activate from the back of the car but no fuel flow. So now, I need to find a couple of fuel pumps for my Z. Any recommendations?
Roy
Roy L. Carman
NCM Lifetime #1468
Old 03-11-2022   #17
tccrab
tccrab's Avatar
Jerrys Gaskets.
If he doesn't have them he will know where to get them.
That being said, there is an option of using only one pump, see Marc Haibec's site for details.
Crabs
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 03-11-2022   #18
You would need to apply UV light to a prom for over 25-30min w no other light seeping in to erase a 2732 type eprom. Before flash proms, that was part of the process for reprogramming an eprom.
Flash proms were a godsend if you do ur own tuning.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 04-12-2022   #19
Jetjock
Jetjock's Avatar
I was able to get the car started today after putting in one of the old pumps and running on just the primary pump. I'm waiting on the brass Y connector from Carter and I'll pull out the old one and put in the new setup. At least it started.
Roy
Roy L. Carman
NCM Lifetime #1468
