Old 11-20-2021   #11
Default Re: Dropping a z one inch
Originally Posted by conesare2seconds View Post
Hmm. I haven?t seen one in a while, thought it was more complicated. If it wouldn?t be hard, maybe it would make a good HOTB how-to.
It's just a composite spring with a hole drilled in it. You would think the hole would have been molded in the material to guard against possible splintering or separation of the material,not the case. The adjuster looks like a mushroom with a threaded shaft.
Z51JEFF is online now   Reply With Quote
Old 11-24-2021   #12
conesare2seconds
Ah. I spotted your posts on this over at the big Forum. Doesn?t look hard. Near as I can tell, it works by pulling the spring tight (pre-loading).
