Old 12-02-2021   #11
cadillac531
cadillac531's Avatar
Default Re: Idle Quality Issue
Spark plug gap was revised from 0.035 to 0.050, just to improve idle.
I didn't change them to the .050, I still have them gapped at .035.
Constantine
Registry Founding Member #0235
1991 Corvette ZR-1 -- Stock, 94 ZR-1 exhaust system, muffler delete.
1956 Chevrolet Belair -- Pro Street, 531ci Cadillac, 8-71 Blower, 8pt roll bar, built TH-400, 9" rear, 1,100 HP -- Street Car.
https://www.youtube.com/watch?v=z8y4cwcvK0s
1968 Mustang "Pegasus" -- Zeeker Chassis, 584ci Dart Block, Brodix Big Brodies, 2-1150 Dominators, FTI 'Glide, 1168 hp, best ET & Trap(holding back) 8.57@159 -- 7.9X -- 1/4 mile car.
1970 Chevelle -- 468ci, TKO600, shaved and smoothed everything.
cadillac531 is offline   Reply With Quote
Old 12-02-2021   #12
tccrab
tccrab's Avatar
Any ECM from any year ZR1 will work in any year ZR1.
The PROM or MEMCAL chip is year specific.
Crabs
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 12-02-2021   #13
cadillac531
Crabs
OK, Great. That's what I thought, but figured I would double check.
Constantine
Old 12-05-2021   #14
cadillac531
So about 15 years ago, I bought an LT5 that came with an ECU, well, unless something has to be done differently, this one doesn't work for the LT5. I installed the PROM and plugged in all 4 ECU connectors, but when I switch the ignition on, I get the SYS in the dash and it won't start.
I, then re-installed the PROM into the original ECU, and it starts fine. It, also seems as though my ECU issue is heat related. I started it and let it idle, and tapped on the ECU and the ignition didn't break up and die. I'm guessing there might be a solder or some element inside the ECU that is breaking down after 20-30 minutes of driving.
Are there solders or components in the ECU that are common to fix that maybe I can open it up and take a look? Has anyone had an ECU refurbished? Where is there a good shop to send the ECU to?
Thanks.
Constantine
Old 12-05-2021   #15
conesare2seconds
I think Marc H rebuilds them.
Old 12-05-2021   #16
cadillac531
OK. I also found this webpage today while doing some searching: http://www.zr1ecm.com/index.html
I'm going to contact this guy too and see what he thinks.
Thanks.
Constantine
Old 12-09-2021   #17
32valvZ
32valvZ's Avatar
Are you sure the prom was seated 100 percent? I had a similar issue where when I dropped the hood I would hear the idle change a bit... I thought it was strange, but let it go.... until one day it wouldnt start at all. I opened up the ECU and one of the locks for the prom wasnt fully seated... car was fine after that. Have you had a chance to drive the car around after putting the ECM and prom back in? Just a few thoughts I had.... Good luck!
[B]1990 #2815[/B]
Ported Plenum & IH (by Pete)
Haibeck Chip
Rebuilt FPR (by Phil)
FIC Injectors
Watson LT Headers
3" Stainless Works exhaust
Lingenfelter Open Air Lid
Bill B Built Transmission
Shifter & C Beam Plates
[B]SOLD[/B]
Old 12-09-2021   #18
cadillac531
When I removed the PROM, the locks were pretty tight. I haven't had a chance to drive it around with the PROM re-installed, but that was the very thing I was planning to do next. I just have to find a day I can take it out and drive, while also having my wife waiting at home with the truck/trailer if it does die out.
I'll post up again once I have a chance to run it for about 40 minutes. That should be more than enough time for it to act up again.
Constantine
