09-29-2021 | #11 | |
Re: Throttle body uh-oh moment...
Sent from my BBF100-2 using ZR-1 Net Registry mobile app |
09-29-2021 | #12 |
The original throttle blade screws are spot welded on the ends to keep them from backing out. Before removing the screws the spot welds have to be ground off (I use a Dremel tool with a small cut-off wheel) otherwise the threads in the shaft will be damaged. When re-assembling throttle blades I use red Loctite 263 and never had an issue in 12 years.
09-29-2021 | #13 |
i thought those blades had some type of sealing goo in the bores and not supposed to remove it?
95 admiral blue z(sold)/ / 93 ruby z(sold) 91 steel blue z/95 aqua z haibeck 510, 91 callaway 415 areobody #5 |
09-30-2021 | #14 | |
OP: But, that said, if yours idles properly w/o the (DAC(?)) stuff, then maybe all is well w/o it. In fact, the stuff being referred to (I believe) is a work-around for the trial and error time it takes to get a precise fit. But, by taking the time yourself, you may have negated the need for the "goop". (But, I defer to Marc Haibeck on that!)
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 09-30-2021 at 10:24 AM. |
