09-11-2021 | #11 |
Re: 3rd brake light not working. CHMSL
Did you check for proper ground? I don't remember how ground was routed to the sockets but if your lower brake lights work and the switch is new it's likely that current is available at the sockets. So maybe an issue with grounding?
I'd check for both, ground and current at the sockets first and then follow the path that doesn't work. Sent from my SM-G991B using ZR-1 Net Registry mobile app
ZR-1 #638/1991 |
09-11-2021 | #12 |
I haven?t checked a ground. I did get the FSM recently and will check it for the ground location- thanks
Here is what the wires look like going into the SLS. The light blue wire is for CHMSL if I understand correctly? White goes to the turn/hazard switch assembly if I understand the FSM. What is the orange - a ground? What?s the small blue plug? There is some tape on the three wires going into one of the SLS connectors. I?ll have to take it off and see what I see. |
09-11-2021 | #13 |
It's the switch,I've replaced it 3 times in 15 years. One down side to doing the Euro taillight conversion,when the switch goes out you have no brake lights at all.
09-11-2021 | #14 |
I replaced the switch. I was fully expecting a done deal after replacing the switch based on all the good threads I found in search.
09-12-2021 | #15 |
Orange is current. That's where your energy comes from. Should attach to the center lug of the three.
ZR-1 #638/1991 |
09-12-2021 | #16 | |
09-12-2021 | #17 |
Please spend the $10's a buy the second brake light switch, one controls bumper lights the other controls the high mount. BOTH need to be working.
09-12-2021 | #18 | |
The orange white and blue go into the SLS. The second blue connector with the grey and a black/white wire also goes into the SLS. No? |
09-13-2021 | #19 |
Only the triple connector is involved in brake light action. As already stated: the center one feeds energy, two outer ones route it to the brake lights when the switch is engaged.
The other connector to my knowledge disengages the cruise control but I'm not 100% sure. You may try to bridge the connector with a bridge lead center-left and center-right which should engage your lights. If not there is a broken circuit. Also you can measure resistance between the connector and the bulb socket to check for a broken circuit. Refer to the FSM to find out which wire is yours. Again: easiest point to start from is to measure at the third brake light sockets. You either lack positive or ground. Find out what's missing and follow the path down to either the body or switch. Sent from my SM-G991B using ZR-1 Net Registry mobile app
ZR-1 #638/1991 Last edited by Matt B; 09-13-2021 at 02:46 AM. |
09-13-2021 | #20 |
Anybody working on this keep in mind you cannot unplug the switch and just leave it and get back to it latter. Once the switch is unplugged the lights will stay on,ask me how I know.
