Old 08-24-2021   #11
conesare2seconds
Default Re: ZR-1 Friendly Jack and Ramps?
I generally use a Kwiklift. With the optional cross bar, cleaning and service is pretty easy. For times I need to work on brakes or suspension I use Rennstands. They solve the problem of how to place a jackstand near the same spot I?ve placed my floor jack and they come with pinch weld adapters. They weren?t especially cheap but I find the car is very stable when positioned on all four.
https://safejacks.com/products/the-r...ck-single-unit
Old 08-25-2021   #12
HAWAIIZR-1's Avatar
Originally Posted by Erik View Post
Thanks, guys.
I have the V2V bars installed, so that makes that easier for me.
You are welcome and glad if the info helped someone.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 08-25-2021   #13
HAWAIIZR-1's Avatar
Thanks for sharing. I especially love those Rennstands. Nice, high quality looking products and no price is too much for safety. [emoji847]🤙🏼
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 10-03-2021   #14
ghlkal
ghlkal's Avatar
Default Jacking with V2V no-flex bards
Erik and Hawaii,
I'm considering the Vette 2 Vette no-flex bars, but I'm concerned about lifting the Z on my 2 post life. It seems as if you guys are lifting on the bar itself, or where it bolts to the frame, and that works OK. Is that right?
Thanks
1990 ZR-1 #2180 Red/Black
Many of the usual mods for 460HP, tuned by Marc Haibeck
ZR-1 Net Registry Member #1548
Old 10-03-2021   #15
HAWAIIZR-1's Avatar
Default ZR-1 Friendly Jack and Ramps?
Originally Posted by ghlkal View Post
Erik and Hawaii,
Thanks
ghlkal,
Not on the bar itself, but on the bracket where it bolts to the frame and mounts the helm joint on the bar. So it os actually on the bracket. If I were back in Japan with my car I could show better pics of the mounting area, but it is perfect for the rubber block of the Quickjack. The photos I posted earlier are the best I have. It you see the bars installed by itself in photos, you can clearly see where to place your lift points.
https://www.motortrend.com/how-to/17...d-d5580fcad325
Having said all that, after looking at the photos and depending on your lift, I would get that flat spot where the Jack stand is usually placed in the front, and on the rear in that pocket on chassis near the area right behind where the no flex bar mounts to.
I used to put my Jack stands in that slot on the frame.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 10-03-2021   #16
1993C4LT1
I use 2 piece race ramps when I don't need to take wheels off. They have been great.
1993C4LT1 is offline   Reply With Quote
Old 10-04-2021   #17
Young1
Young1's Avatar
I want Quickjacks bad. I have V2V bars so that will get it up even higher. I have been on the hunt for used for a while.
Steve Young
Second Owner
SOLD
SOLD
Old 10-04-2021   #18
HAWAIIZR-1's Avatar
You won?t regret it. Costco had them, but I don?t know about now. If you can afford to get the new and improved TL model it lifts even higher. Unless you can find a used locally the shipping might outweigh the cost and I don?t know you want used equipment like this. JMHO.
https://www.quickjack.com/car-lifts/5000tl/
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 10-07-2021   #19
do you use the Rennstands on the Kwiklift? I use jack stands on the center bridge with kwiklift for the front, but the rear becomes more of a challenge and looking for a good solution for lifting the rear while on the Kwiklift.
Old 04-23-2022   #20
davidijaxson
ghlkal,
HawaiiZR-1, for the QuickJack 5000TL do I need to purchase anything additional from QJ? I am ready to pull the trigger but want to get everything I need first go around. Thanks in advance.
davidijaxson is offline   Reply With Quote
