Old 06-17-2021   #11
conesare2seconds
Default Re: In Defense of J55 Brakes
Pads make a big difference. When I autocrossed all the time, I put on new pads every year and once accidentally switched from Hawk HPS pads to HP+. I daily drove the car and the HP+ likes a little heat. The first stop or two of the morning commute the brakes were plain weak. After 6 months of scaring myself and a close call or two I gave up and switched back. The Plus pads technically had better specs but weren?t best for my application. The HPS pads didn?t stay hot in autox they way they would have for track day use and worked better than Plus at everyday temps Lately I?m using HPS 5.0 on the ZR-1 and am happy so far.
Old 06-17-2021   #12
Ccmano
Ccmano's Avatar
We put EBC red stuff pads on my wifes CLA45 it stops from 70 in 150ft stock, the pads have a lot more initial bite than the benz pads and zero dust
Just be prepared to go through rotors faster. Benz uses soft rotors to begin with, which further enhances the braking performance.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 06-17-2021   #13
Originally Posted by Ccmano View Post
Just be prepared to got through rotors faster. Benz uses soft rotors to begin with, which further enhances the braking performance.
H
I picked up some Brembos that are better
Old 06-17-2021   #14
sleazy rider
sleazy rider's Avatar
when i put the brembo's and ccb rotors on my 2007 z06, i put the z06's brakes and wheel/tires on my 1991 zr-1. have not done any comparisons but they work.
#1 c6 z06 caliper vs c4 j55 caliper
#2 c6 z06 brake assy on c4
#3 rear z06 rotor vs c4 rotor
ps. how do i rotate a picture cw/ccw?
sleazy rider is offline   Reply With Quote
Old 06-17-2021   #15
Young1
Young1's Avatar
Be sure to install the DRM bias spring. It makes a noticeable difference.
Steve Young
Second Owner
SOLD
SOLD
Old 06-18-2021   #16
What wheels are you using
Old 06-18-2021   #17
Matt B
Matt B's Avatar
As my Z still has the factory installed rotors and pads I'm thinking about some modernization, too, maintaining the stock setup. Powerstop Z26 would be the stuff of choice for me. Just one consideration: are these slotted and drilled disc's really anything as close to "quiet" as powerstop claims?
I used to have drilled rotors in the past in one of my Audi's and these were an awful choice as they caused buzzing/humming noises and even slight but noticeable vibrations up to the steering wheel.
When speaking about stock brakes also noise is a consideration as my Z is a Sunday Sunday afternoon bullet and not a track tool...
Sent from my SM-G991B using ZR-1 Net Registry mobile app
ZR-1 #638/1991
Matt B is offline   Reply With Quote
Old 06-18-2021   #18
1991 Corvette ZR-1
The Z26 package has been quiet as a mouse for me. I?ve been using it over a year now and no noise of any kind. The rotors are zinc plated, so it is a nice touch and good to know you don?t have to look at rusted parts of the rotor not in use. Low dust pads. The only thing that you might even consider an issue is on the rare cases there is enough pad dust accumulated that gets wet from say driving in the rain, it can run out onto the wheel and dry out. It requires some extra effort to remove from the wheel but a very minor issue.
1991 Corvette ZR-1 is offline   Reply With Quote
Old 06-18-2021   #19
Matt B
Matt B's Avatar
Great, thanks for that insight. Then I will order my set! Seems to be a wise upgrade.
ZR-1 #638/1991
Old 06-19-2021   #20
If u are going to go w 18/19? wheels like the OEM C6Z 5 spoke, the stock calipers and rotors look puny.
What I like about the bigger brake, beyond the aesthetics, is how light the pedal pressure needs to be to stop in typical driving situations. I end up stopping sooner than I think I will.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
