Old 05-09-2021   #11
Default Re: 1990 valet key Vs 1991
Originally Posted by 32valvesftw View Post
Can you epoxy the 90 key/switch assembly into the 91 Bezel?
I would drill out the hole for the 90 key and mount it, you would need something to cover the hole for the LED
Old 05-10-2021   #12
max76
The 1990 key switch is bigger than 1991?
In the next days I'll receive the 1991 radio bezel and the shifter consolle...I'll like to use the 91 key but when I will have the pieces in hand I'll see what to do...
max76 is offline   Reply With Quote
Old 05-10-2021   #13
Looking at a picture of the 91 bezel you will need to drill or notch the ears for the 1990 key cylinder
Old 05-10-2021   #14
max76
Thanks for the suggestion...when i'll have the parts in hand i'll decide what to do for fit my key in 91 hole...or...maybe i'll try to use the 91 key in 90 car... ;-)
Old 05-10-2021   #15
aafc
aafc's Avatar
Back in 2004 when i installed the auto transmission, I did not want to cut the
org radio bezel. So i got a radio bezel used from a non ZR-1 (1990).Drilled
hole and mounted the power switch. Then had decals made to show the
power settings on the radio bezel.
Attachment 15301
aafc is offline   Reply With Quote
Old 05-10-2021   #16
max76
Attachment 15301
Yes...this was another possibilities...but, as you say, if you take the non zr1 radio bezel lose the yellow letters...can you show me the pic of your decal? Here decal shop tell me that the letters are to much little and there are difficult to cut...
Old 05-10-2021   #17
aafc
aafc's Avatar
See if this works
https://www.zr1.net/forum/picture.ph...pictureid=4572
Old 05-11-2021   #18
max76
Yes...it's work...nice decal...
Do you know if there is a color code for the gray of the 90/91 radio bezel/shifter console?
Old 05-11-2021   #19
aafc
aafc's Avatar
I do not the code for the radio bezel of the 90/91. It might be the same for all
C4's in that year. Check in the NCRS section and ask them.
Old 05-11-2021   #20
The font is the other part of that.. if I knew the font I would do the same for my bezels
