Old 02-08-2021   #11
ghlkal
ghlkal's Avatar
Default Re: DIY euro tail lights
Originally Posted by Erik View Post
Look good. How did you do that?
x2 -- interested in the process
1990 ZR-1 #2180 Red/Black
Many of the usual mods for 460HP, tuned by Marc Haibeck
ZR-1 Net Registry Member #1548
Old 02-08-2021   #12
Let me see if I can get the rest to work.....pointless if I cant make the housing, etc....
Old 02-09-2021   #13
The bulb sockets for these are specific to the housing and the part number is AC DELCO LS39 and LS96. The wiring at the brake switch has to be modified but I can't remember how,I'm sure somebody will have the info here.
Old 02-09-2021   #14
The brake light signal can be had by tapping into the CHMSL circuit. Much easier than doing it at the brake switch.
Old 02-09-2021   #15
tpr60
If I remember correct you can tap into the 3rd brake light wire to work the brake bulbs, you will also need to cut the white wire coming out of the turn signal connector at the bottom of the steering column to keep from having electrical feed back. I did this euro light conversion 20+ years ago, still have the ZR1.
tpr60 is offline   Reply With Quote
Old 02-10-2021   #16
It's starting to come back to me,I removed,didn't cut the white wire at the switch,wrapped it to isolate it. I believe the light blue wire in the wiring harness is the 3rd brake light for base cars with the light in the bumper,this wire runs all the way to the back of the car an stops at the main connector at the bulkhead. On the opposite side of the harness connector is the empty cavity where you would install a terminal connected to the EURO setup. In my install not a single wire was cut,spliced.
Old 02-10-2021   #17
I ran a new wire from the dash to the back for the brake lights. There is a reason for 2 brake light switches. I cut the wire under the dash to by pass the turn signal flashing. but then ran the new wire from to the back of the car..
Since my taillight harness had been messed with prior to me owning I just rebuilt it with the euro sockets and soldered everything
Old 02-10-2021   #18
I popped the white wire out of the harness connector. Then ran a wire from the targa hoop down to the back and used scotchlock for connection to harness I built.
Old 05-27-2021   #19
max76
Hi guys...
Does anyone have instructions on how to mount the wiring for european tail light?
I know that some years ago ecklers or other site had the scheme...
max76 is offline   Reply With Quote
Old 06-12-2021   #20
Too hot to be pulling off parts, started making the housing
