02-04-2021 | #11 |
Tensioner pulley option
http://www.zr1.net/forum/showthread.php?t=20187
https://www.ebay.com/itm/Mustang-BIL....m46890.l49292 Sent from my iPhone using ZR-1 Net Registry
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 Last edited by HAWAIIZR-1; 02-04-2021 at 12:28 AM. |
02-04-2021 | #12 |
Re: Tensioner pulley option
Cliff,
Any particular reason you prefer boss on the inside? Flat surface outside to keep it free of dirt build up. Right? Last edited by secondchance; 02-04-2021 at 06:17 AM. |
02-04-2021 | #13 | |
The bearing is pressed in from the front of the Pulley into the Boss. The Rear of the Pulley is shown above. The bearing is prevented from drifting out through the Boss as can be seen above with the lip covering the outer race of the bearing. With the bearing bolt holding the bearing to the tensioner it is impossible for the Pulley to drift out toward the engine with the Boss on the Tensioner side.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-05-2021 at 01:57 AM. |
02-04-2021 | #14 |
Erik,
https://www.ebay.com/itm/Mustang-BIL...MAAOSw9NxTwEQC Above is the aluminum pulley some of us have been using. Cliff, I fully agree with your detailed analysis. Aluminum pulley failure posted a few months ago, I believe most likely, is from aluminum wearing out resulting in thin wall thickness where the belt is running. At some point, combination of thin wall and heat generated from friction may be resulting in break up of pulley surface. Of course, with steel, this is unlikely to happen. My 84 Z51 came with powder coated pulley. For some reason, I cannot remember what type the original pulley was. When I replace my coolant this spring, I think I will replace aluminum to steel pulley. I am seeing uneven wear on the pulley surface laterally and don?t want to take any chance of failure. |
02-04-2021 | #15 |
If anyone is really into bling, I found polished aluminum billet pulley also.
https://www.ebay.com/itm/5-0-BILLET-...QAAOSwVFlT0m8~ |
02-04-2021 | #16 | |
But the NCRS would wag their finger at me.
1990 ZR-1 # 996 "All Corvettes are red. The rest are mistakes." - John Heinricy |
