Old 12-02-2020   #11
Erik
Default Re: It's Always Something, dammit.
Originally Posted by longhorns05 View Post
New starters are available. The PO of my 94 had the starter professionally rebuilt before selling the car. A month or so later, it wouldn't crank when heat soaked. Only after the hood was left open for an hour or more, would it crank and fire up. Bought one of these and haven't had a problem since.
https://www.ebay.com/itm/Delco-Remy-...0AAMXQQQhRfi97
That is very good to know. Thanks very much!!! Thanks very much!!!
1990 ZR-1 # 996
"All Corvettes are red. The rest are mistakes." - John Heinricy
Erik is offline   Reply With Quote
Old 12-02-2020   #12
Tripler
Tripler's Avatar
Agree . Just change the whole unit out and be done with it
[emoji106]
Sent from my SM-A205W using Tapatalk
Tripler is offline   Reply With Quote
Old 12-02-2020   #13
Erik
I went out and did about 5 or 6 spins of the starter, and it finally ended up catching. Let it run for a good while, and turned it off. Crossed my fingers, turned the key, and she started right to life again. Did it a couple of more times and all was good. Took her out for about an hour and a half run, including a stop for gas, and all went well.
I am thinking the new starter might be a good thing to do. Then shoot the old one over to Marc for a rebuild.
1990 ZR-1 # 996
Old 12-02-2020   #14
ZR2
I have a local company here in Baltimore that I have had several starters and alternators rebuilt. Typically a one day turn around. They have been very good and not very expensive. Let me know if you need help. Thanks Mark
ZR2 is offline   Reply With Quote
Old 12-06-2020   #15
bowtiguy
I did the same thing. part is an EXACT replacement. I then rebuilt my stock unit. cleaned -repacked bearings, cleaned solenoid etc.. Now I have a spare.
bowtiguy is offline   Reply With Quote
Old 12-06-2020   #16
Erik
Just ordered mine. And yes, I'll do the same thing that you did with your old one.
1990 ZR-1 # 996
Old 12-06-2020   #17
Erik
Thanks for the tip!
Followed your suggestion.
1990 ZR-1 # 996
Old 12-07-2020   #18
spork2367
The plenum pull isn't a big deal. I would definitely try to get the old starter working and keep the new one as a spare. These rarely have issues that aren't repairable.
Old 12-11-2020   #19
Erik
Definitely gonna have a spare.
1990 ZR-1 # 996
