Old 11-21-2020   #11
KJL
Default Re: Cam Position Sensor Removal
Originally Posted by 32valvZ View Post
Honestly, I wouldnt use anything to try to fix that crack... you wouldnt want RTV or any kind of epoxy floating around in the oil galleys and I doubt super glue would hold. Its now an official paper weight.
Yes but..... it?s not like I can just run to NAPA and replace it. It still works. The leak was minor. The oil pan gasket leaks much more. It seems a little super glue in the crack with a skim of high temp silicone would be worth a try. Epoxy may be an overkill and more risky. My guess the sensor itself is bedded in epoxy internally and should be fine even with a crack in the outer shell. The crack is barely visible.
1995 ZR1 #159
1992 ZR1 #280
1996 Collectors LT4 (Stock)
572 rwhp
Old 11-21-2020   #12
HAWAIIZR-1's Avatar
I agree with you to attempt a repair. I didn?t see the crack you have, but I repaired the one on my 90 with very minimal JB Weld and it was fine.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 11-22-2020   #13
32valvZ
32valvZ's Avatar
Just get one from Phil and be done with it... I had mine in a few days and all has been well since.
Old 12-01-2020   #14
KJL
Update:
Repaired the crack with JB weld for plastic. Used a Dremel to plow a small groove along the crack to give it more bite and roughed up with 180 sand paper. Use silicone around the o-ring seal as well. Did not install until everything had cured. So far no leak. Need more heat cycles to be sure but why not try.
1995 ZR1 #159
1992 ZR1 #280
572 rwhp
Old 12-01-2020   #15
HAWAIIZR-1's Avatar
Update:
Repaired the crack with JB weld for plastic. Used a Dremel to plow a small grove along the crack to give it more bite and roughed up with 180 sand paper. Use silicone around the o-ring seal as well. Did not install until everything had cured. So far no leak. Need more heat cycles to be sure but why not try.
Good job! That sounds like it will work well. Best wishes!! [emoji1303]🤙🏼
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 12-09-2020   #16
Erik
Update: Sensor is cracked. Starts on top and travels down the side. I think it stops just short of the seal. There is mold seam there as well which makes it harder to verify where the crack stops and the seam starts. I need to get a closer look with a jewelers loupe.
As luck would have it I ordered a new one from Phil but if I can, I would like to try and repair the crack if possible. The sensor still works. Any thoughts? Super glue? Epoxy? RTV? How much clearance between the sensor and the cam?
Only a little oil cam out when I removed it.
Phil has cam position sensors?
1990 ZR-1 # 996
"All Corvettes are red. The rest are mistakes." - John Heinricy
Erik is offline   Reply With Quote
Old 12-09-2020   #17
G8nightman
G8nightman's Avatar
Yes
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
G8nightman is offline   Reply With Quote
Old 12-20-2020   #18
ZR1CK
Who is Phil and how do I get in touch with him? Just replaced my cam sensor but would like a spare.
ZR1CK is offline   Reply With Quote
Old 12-20-2020   #19
HAWAIIZR-1's Avatar
Phil is Jagdpanzer on here so you can message him.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 02-23-2021   #20
Matt B
Matt B's Avatar
Gentlemen, is THAT the crankshaft sensor?!? It's located right below the left cylinder head (driver side). Mine is leaky but it isn't round. I removed a small metal piece (like a small fender, tray, latch, whatever) that was secured with an 8mm nut.
The Sensor itself seems to be not round, there is no twisting possible. I can wiggle it, but it doesn't come out. What am I doing wrong?
ZR-1 #638/1991
Matt B is offline   Reply With Quote
