#11 | |
![]() Join Date: Jun 2006
![]() Good luck! Hans ![]()
#12 |
![]() Join Date: Aug 2015
Please tell the guys at Austin Corvette to call me (832) 748-1286 and I'll help as I can from here..
Steve Schroder Crossed Flags Performance, LLC Sent from my SM-G950U using ZR-1 Net Registry mobile app |
#13 |
Thanks Steve. Looks like Code 36. They are saying module or ecm.
Ross Lone Star State 94 ZR-1 #293 |
#14 |
While failure of the DIS or ECM units is certainly a possibility, the higher likelihood is an issue with a connector. That possibility should be eliminated before replacing these expensive and hard to get parts. Following the diagnostic procedures in the FSM is key here.
H Sent from my iPhone using ZR-1 Net Registry
#15 | |
832 748 1286 Steve Sent from my SM-G950U using ZR-1 Net Registry mobile app |
#16 |
Do yourself a favor and call Steve...
Keep in mind you can't just go to the dealer or parts store buy an ECM or DIS unit, plug it in and see if it solves the problem. Then, if it doesn't, return it an get your money back. Throwing parts at it to see what solves the problem can get expensive real fast! Each of those units will cost a minimum of $1000, if you can find one. The ECM can be rebuilt. Haibeck (www.ZR1Specialist.com) provides that service. The shop needs to do proper diagnostics, not just random parts replacement. These cars with first generation computer system (OBD1) diagnostic codes will only point you in the general direction of the problem. They don't PinPoint the exact component that is failing. That's why the FSM diagnostic trees need to be followed to narrow it down. Keep us posted on how this goes. H
#17 |
ECM is $87.00 at Autozone and cheaper on Rockauto. Hope their pricing is correct.
#18 |
You need a Tech 1 to diagnose.. there can and likely are more common failures that can cause your issue. Attached is the best I can do remotely. These are NOT common to L98/LT-1 platforms. They are unique to the LT-5.
See attached..20201109_134210.jpg20201109_134223.jpg20201109_134245.jpg20201109_134256.jpg20201109_134319.jpg20201109_134329.jpg Sent from my SM-G950U using ZR-1 Net Registry mobile app |
#19 | |
![]() Join Date: Feb 2011
No way is that an LT5 ECM! Sent from my iPhone using ZR-1 Net Registry
#20 |
Lou is absolutely correct. The LT-5 ECM and DIS are not available in the open market. You are very likely looking at an LT-1/4 remanufactured unit. Won't work.
Sent from my SM-G950U using ZR-1 Net Registry mobile app Last edited by jss06c6; 11-09-2020 at 04:34 PM. |
