Old 11-11-2020   #11
Default Re: HEADLIGHT UPGRADE
LED headlights is the best option. I went from stock, to Hellas, to HIDs and then finally LEDS. So impressed both my ZR-1s now have the same LED upgrades.
Old 11-11-2020   #12
Thanks for that assessment! (I wuz wondering what the difference might be!)
Back to the subject of blinding on-coming traffic, those headlights, including LED type that met legal requirements have a very distinct cut-off or 'drive line' on the low beam setting. If that cut-off is not adjusted to slant down toward the road and in no way angle up toward on coming dirver's eyes, then YOU are creating a hazard - and the very impetus of the brew-ha-ha going on over ANY non-stock headlights. (Proposed legislation in some States would ban anyone except some "certified" mechanic from buying and installing headlights. NOBODY wants that!)
However, (again) working in our favor is the fact that the center of our lights are only about knee high above the road surface. So, combined with the unmistakable cut-off/drive line, keeping the low beam glare below eye level of on coming traffic is easily accomplished. That said, high beams and those off-road type flood lights do create a hazard by on coming traffic.
These type lights (attached) have made their way to some vehicles and were never approved for highway driving.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 01-16-2021   #13
ZR2
I just did the Hella H4 bulb upgrade for my 94 and ordered multiple H4 bulbs, 55/60/, 55/80 and one more I think it was 80/100, cant remember. I installed the 55/80 bulbs and can say that even on low beam I feel like the light is sharper and on high beam definitely is better. I try not to be out much after dark......too many deer, but am very pleased with these lights. Really nice upgrade.
ZR2 is offline   Reply With Quote
Old 01-30-2021   #14
ZuggZR1
ZuggZR1's Avatar
I used these on my 1990 C4 ZR1
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
You will need these as well:
https://www.superbrightleds.com/more...lbs/2179/5079/
Attached is a picture of high and low beam pics
George Zugg
1990 DRM 500 ZR1
build#952
ZuggZR1 is offline   Reply With Quote
Old 01-31-2021   #15
ram_g
Originally Posted by ZuggZR1 View Post
Not necessarily, you could do the foglamp relay mod ("Yun mod") instead.
ram_g is offline   Reply With Quote
Old 02-06-2021   #16
VikingTrad3r
VikingTrad3r's Avatar
This is what I use and they have a beautiful cut off. And they?re cheap. And they?re bright as all get out. Make the lights look like a new car at night from inside. For me it was just plug and play maybe I lost fog lights or something but I don?t care
VikingTrad3r
Calgary, Canada
1991 ZR1 # 888 - daily drive whenever possible
1991 ZR1 engine from unknown sn.
1990 Z51 zf6 being built into narrow body ZR1 racer
1987 z52 auto - sold
1986 'z31' 4+3 - sold
1985 Z51 auto - sold
VikingTrad3r is offline   Reply With Quote
Old 02-18-2021   #17
Flyman 27
Flyman 27's Avatar
I was told that these GE NightHawk lights were the best. They were $500/pr until recently. Walmart has them for $75 ea but you have to wait for the next shipment maybe. Act fast when they come in, they are popular.
I used them on my Z and couldn't be happier.
https://www.walmart.com/ip/GE-Lighti...Pack/929156431
They have a very highly defined high/low beam separation.
Good review on them:
https://www.corvetteactioncenter.com...ht-for-c4.html
91-#1935 Black/black & gray, Haibeck 500
Cams by Pete
Flyman 27 is offline   Reply With Quote
Old 02-18-2021   #18
mpiecyk
Flyman 27,
Are the G E Nighthawk 69822 lights plug and play or will a load resistor be needed for each light ?
Thanks in Advance
Mike P.
mpiecyk is offline   Reply With Quote
Old 02-19-2021   #19
Flyman 27
Flyman 27's Avatar
I grounded the green wire on the fog light relay and that allows everything to run properly.
Cams by Pete
Old 02-20-2021   #20
Originally Posted by mpiecyk View Post
Flyman 27,
Thanks in Advance
Mike P.
I have those on my car too.. no load resistor.. I added one relay and skipped the load resistor.. works fine
