#11 | |
![]() Join Date: Aug 2006
What you are describing is a classic symptom of solenoid contacts gone bad. Jim V. Has a few solenoid rebuild kit; I think. If you do replace the starter, don?t trash the old one. |
#12 |
![]() Join Date: Aug 2004
Is that what the whole relay circuit modification is correcting ? Is this what degrades over time causing the no start issue?
91 Turquoise Metallic Haibeck 525 #0134 |
#13 |
![]() Join Date: Mar 2018
I had the exact same issue with my '92 after I got it. The problem was "finger tight" battery terminals.
#14 |
![]() Join Date: Feb 2012
It all depends on the fingers
#15 |
#16 |
![]() Join Date: Apr 2013
I had that happen once. At a club meeting. Got 4 or 5 guys to push and it pop started. Got home and it started right up. Did the relay mod and never a problem since...
#17 |
![]() Join Date: Jan 2010
Big John can remove lugnuts using only his fingers!
Doesn't need a jack either! Holds the car up with one hand and changes the tire with the other! 😀 |
#18 | |
![]() ![]() Join Date: Nov 2007
The clutch safety switch is not an issue beginning with the 93 MY cars due to a circuit design change utilizing a relay to handle the current, so the 93+ cars seldom (if ever) have an issue with the clutch safety switch. However, a relay can be installed in the 90-92 cars which provides the same relief to that safety switch as the 93+ cars enjoy by re-routing the high current carried by the purple wire from the safety switch through the contacts of a relay installed behind the battery compartment. The current from the safety switch activates the relay instead of the starter which greatly reduces the current/arching that was the issue with the 90-92 safety relays. See attached... .
#19 |
![]() Join Date: Sep 2008
Let's start here:
Try an alternate key. I always keep a new spare hidden in the car just for such fun events. Make sure if you have aftermarket floor mats that you try removing them when this happens to make sure that you are getting the clutch all of the way down to override the clutch safety switch. Observe the volt meter when this occurs. Does the needle deflect when you go from run to start. If it does not, then you are likely trapped in either the VATS protocol or the neutral / clutch switch protocol. If it deflects then likely a starter issue. If the clutch switch is the suspect, there is an override wiring procedure to update your 90. Search the forum here and you will find it discussed. If the key was the original culprit, likely still is until ruled out. Then try this: Check simple things first: 1- Make sure that if you have the usual logo replacement floor mats that are 3 times the thickness of the originals, that it indeed lets you depress the clutch pedal ALL of the way. Occasionally, the mat may slide forward and up, and while you think you are depressing it fully, you may be missing it by a little. 2- Check your battery connections. I know they LOOK tight, but grab the wrench and make sure that they ARE tight. 3- Battery? How old? On a Battery Tender? These cars are VERY sensitive to battery condition. If you have even mildly reduced voltage, strange things happen. Check it or charge it, then check it. 4- When you turn the key, observe if you have a deflection of the volt meter needle. It should move when you bump the key. If you see no movement, you may not be getting by the clutch switch, the VATS, or the theft deterrent system. Rule out the obvious and simple causes FIRST. Find the no start sticky and march through it! Let us know of your progress. Marty |
