09-07-2020 | #11 |
Re: Car running rough and Stalling
Well it runs great in low power mode.... I might need to check my tune.
09-07-2020 | #12 |
Found chip paperwork secondary port controls removed... so this is odd, but narrowing down the problem hopefully
09-20-2020 | #13 |
Well this turned out to be injectors; they were only a few years old but prior to this I had an issue with bad/old fuel ... might have done them in ..... I replaced yesterday and car ran perfect...
09-20-2020 | #14 |
Was it all of them, a few, one? How did u determine?
09-20-2020 | #15 |
I knew it was some sort of fueling issue;(Mr Haibeck helped me rule out some sort of ECM issue) I tested secondary relays(good), fuel pressure was always good so tried the Fuel Injectors and problem is gone. It was the secondaries only(had a different batch # on it) very odd... they ohmd fine and didnt leak
09-20-2020 | #16 | |
Had a similar issue w injectors recently. 2 bad secondary injectors altho they did ohm ~ 45ohms. Had bad coils as well.
