Old 11-08-2020   #11
Zman
Default Re: Switching up a DRM 385
Originally Posted by Demps View Post
I?d imagine that?s just about perfect. What do you think?
Ted
After further review..........Perfect. The ONLY thing wrong with this set up is it is not a 441!
Zman is offline   Reply With Quote
Old 11-09-2020   #12
EvanZR1
EvanZR1's Avatar
I had 4.10s on my previous ZR-1 with just top end porting, and it really woke the car up. I think the 4.10s are great on stock/near stock ZR-1s, but are too much gear for anything over 500HP and probably borderline even for that 500HP.
On my current 391 cid ZR-1, I have the stock flywheel and 3.45 rear and I'm very happy with the setup. I ran 176MPH in the standing mile (before final tuning was even finished, which gained me another ~25HP), so I'm pretty happy with it. Ideally with a shorter 5th or overall numerically higher rear I might gain a little bit in the mile, but then I'd sacrifice elsewhere (1/4, 1/2, street, etc). With the current ratio, 5th for me would top out at 220MPH, so a 3.78 rear would probably be better as it would top 5th at 200MPH (doable with my 391 on a long enough straight), and it would make 6th a little more usable (even with the 391, cruising at less than 80MPH in 6th seems sluggish). But that's a fair bit of money for a minor change, so will probably just stick with what I have.
If I were you, for a 385cid with 4.10s, I'd probably drop to a 3.7x gear and stock flywheel.
EvanZR1 is offline   Reply With Quote
Old 11-09-2020   #13
Zman
The current set up is 3:78s with a 15lbs aluminum flywheel. I really like the faster rpm acceleration with the lighter flywheel. I really like this setup while driving alone. I have noticed that with an added person in the car the transmission rattle is a bit louder. I?m very happy with the set up. I wanted a 22lbs flywheel but Jerry didn?t have a clutch kit with that weight flywheel.
Old 11-18-2020   #14
wfot
wfot's Avatar
I am planning a 402 build. Curious as to what the bore/stroke is on the 385?
any audio or video of it? not many 385s out there?
thanks
john
wfot is offline   Reply With Quote
Old 11-19-2020   #15
3:73 with 510hp package and love it for driving. I do run back roads 90% of the time interstates are just to dull.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
