Old 07-17-2020   #11
carter200
carter200's Avatar
Default Re: Fuel pumps?
Good insurance would be to replace the old plastic Y with the billet Y machined by carter200 (CT Machining). This is a plug n play unit.
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 07-17-2020   #12
CamP
Thanks for the input, Marc and Carter.
CamP is offline   Reply With Quote
Old 07-19-2020   #13
CamP
I received the Acdelco EP381 fuel pumps from Rock Auto. They are made in Brazil. Hope this helps folks that avoid Chinese made products.
Old 07-20-2020   #14
CamP
Some additional information that may be helpful to others.
The latest GM 25091503 sending unit gasket does not have 9 holes. You can cut the additional hole into it, but that's a hassle. The SPECTRA PREMIUM LO148 gasket costs a lot less and doesn't require modification.
Several threads suggest the ACDELCO TS3 fuel pump screen for the lower pump. It is too short to work properly. Marc Haibeck suggests the TS2, which is the proper length.
Lastly, no threads mention the replacement of the rubber o-rings for the 9 bolts. Several of mine broke while be removed and require replacement. I'll update when I figure out a properly sized replacement.
Old 07-20-2020   #15
Erik
Thanks Cam. Good information.
Erik is offline   Reply With Quote
Old 07-20-2020   #16
CamP
Update on the always neglected o-ring info for the nine bolts on the sending unit. I found 5mm i.d. x 8mm o.d. viton o-rings at grainger. Should have them tomorrow and I'll update again with a part number if they work.
Old 07-21-2020   #17
CamP
Recieved the viton o-rings from Grainger and they look like the should work great.
5mm x 8mm x 1.5mm Viton
Grainger # 1RHN7
Old 07-22-2020   #18
Erik
You pay more for the privilege too, but good to have a real GM made part.
Old 07-22-2020   #19
Erik
Grainger # 1RHN7
Thanks!
Old 07-23-2020   #20
Erik
Originally Posted by Marc Haibeck View Post
I will mention that I recommend Airtex E3240 fuel pumps. We use ACDelco TS1 (short) and TS2 (long) strainers.
Spectra L0148 sender assembly gasket.
Always replace all of the plastic hose clamps with metal clamps. The plastic clamps sometimes pop open a short time after they are reused. Some of the plastic clamps are developing cracks with age.
Hi Marc.
To clarify, you use one of each of the TS1 and TS2 strainers for a replacement of both fuel pumps?
And I can't find a listing for the Spectra L0148. Where do I find those?
