Old 04-14-2020   #11
Fast36
Default Re: 1990 Seat Belt recall
Yes I saw the report from NHTSA and had a good phone call with them. No resolution sadly.
Fast36 is offline   Reply With Quote
Old 04-14-2020   #12
Mystic ZR-1
Mystic ZR-1's Avatar
Fast 36
What are your concerns?
Originality, the Scarlet Letter of having an
open recall or just safe seatbelts?
Old 04-14-2020   #13
davidijaxson
Just checked the VIN on my 90 and both the right and left sides have open recalls. Sounds like a waste of time to try and get it addressed 30 years later. Given that my belts are not giving me any issues I will used them and hope they don't need replacing.
davidijaxson is offline   Reply With Quote
Old 04-14-2020   #14
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
IF the belts have been and currently are working properly, why ever would you want to replace them?
They don't fail while in use.
The failure, if it occurs, occurs when removed and they will not come out of the re-tractor.
If that happens, yes they then would need replacement.
But if they have not failed in 30 years, there are far more important things to be worried about than working belts.
Drive and enjoy the car.
Marty
Old 04-15-2020   #15
Fast36
Marty
Thanks Marty, I'll try to keep that in mind. Just don't like driving a car with a safety recall active and the seat belt light on constantly.
Rich
Old 04-15-2020   #16
Corvette95
Corvette95's Avatar
Seat belt light is a ground and not associated with recall.
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 04-15-2020   #17
Fast36
Fast 36
I've never had a car with an outstanding safety recall. Every car I've owned if there was a recall, I'd bring the car in to have it satisfied.
Rich
Old 04-15-2020   #18
Fast36
If you are buying a used car from a dealer, ask for either the Carfax Report or their competitor Equifax Car Check Report, or run your own!
Either one will pick up any open recalls on a particular car.
If they do not provide it, or if you are purchasing from a private party, or even just to double check, you can use the following link to the GM Recall Database.
https://my.gm.com/recalls
Best to do this before you buy.
It seemed as if everyone who wanted to trade a high end European car to me, all had bad Takata air bags that had never been replaced. The above reports catch it everytime.
Marty
Thanks Marty, I received the CarFax report at NJ DMV. After that I did all that you suggested in your post.
Rich
Old 04-15-2020   #19
DRM500RUBYZR-1
He speaks truth.
The light can be corrected, almost always a ground, and most of the time under the seat.
Once you fix that warning light, which by the way has nothing to do with the recall issue, my guess is after a week or two of not seeing the light, the recall will become a distant memory.
Again, enjoy that car!!
Marty
Old 04-15-2020   #20
Fast36
Originally Posted by Ccmano View Post
It appears this recall is for the right side seatbelt retractor. Mine is outstanding as well.
H
My recall has both left and right.
