#11 |
I changed the front filter as well (it turned into a true fiasco, I think I ended up pouring 3 gallons of fuel all over myself in the process), and when I’m feeling up for it I’ll go ahead and pull the assembly out and replace the stock plastic clamps to decent stainless pieces. As for the accordion piece, it runs great to redline in a straight line, but I’ll keep the knowledge in the back of my head. I haven’t had the opportunity to fill up and go for another run but I’ll update when I do. Thanks all
#12 | |
![]() Join Date: Nov 2007
#13 |
Also, make sure u unscrew the gas cap to equalize pressure. Same when working on injectors.
#14 |
![]() Join Date: Jun 2005
When I owned Barney, I changed the stock fuel filter several times and never spilled a drop of fuel.
First, I wouldn't do the change unless I had a quarter tank or less. Then I'd jack the front end up way high so the level of fuel was below the level of the filter. Then I'd, loosen the clamp and disconnect the rear connection. The front connection was always a bitch so I'd hold the front fitting with one wrench and break the filter loose with a bigger wrench on the hex on the back of the filter. The small amount of fuel spilled as the filter drained I'd catch in a small drain pan. Installing the new filter was the reverse of above.
#15 |
![]() Join Date: Jul 2016
I’ve always started the car, then pulled the fuel pump fuse, loosened the fuel filler cap, and let it run a couple of minutes until it shut down. Uses up a great deal of fuel between the tank and the engine and drops the pressure in the lines. Makes changing the in line filter less messy. Haven’t ever had any trouble restarting the car, fuel pressure builds quickly when you turn the key to ACC before cracking her over.
