Old 03-22-2020   #11
Jagdpanzer
Jagdpanzer's Avatar
Default Re: virus projects?
New suspension bushings all the way around, 3” exhaust system, replace rear hatch weather stripping
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 03-22-2020   #12
Alas no car projects. I am afraid I am reduced to this. Should have involved my 3 and 6 year old grandchildren to improve the quality. I also have about a month's worth of deferred annual maintenance on my Lionel trains to do, which had been postponed due to January hip replacement surgery. Plus lots of books to read.--Bob
Old 03-22-2020   #13
mcich7781
mcich7781's Avatar
I need to do that too, along w finally clay bar and waxing. I’m like one of those people that doesn’t like to finish off exterior until mechanicals are in the condition that a shiny exterior suggests.
Weird I know.
No not weird. You're just the kind of person I want to find to purchase their old cars from.
Sent from my SM-G955U using ZR-1 Net Registry mobile app
mcich7781 is offline   Reply With Quote
Old 03-22-2020   #14
billschroeder5842
billschroeder5842's Avatar
So, I tackled a noise that was coming from my passenger door. Occasionally there was a vibrating noise that woudl happen a certain low level rpms or on rough road. It came and went so I held off.
I took the door panel off and discover that the metal arm came off of the actuator for the power locks and was resting against the door frame. The plastic piece was brittle and broke. Autozone's "help" section had the piece I needed. I put everything back together paying attention to plugs and wires adding foam and taping as a prevention.
So, first "Corona project" complete.
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
[SIGPIC][/SIGPIC]
Old 03-22-2020   #15
902066
Since I have a lot of time on my hands, I am working on stopping an oil leak at the "oil pressure regulating valve cover plate". I've been reading the helpful hints in the solutions section, and am ready to jack the engine up a couple of inches to see if that makes the bolts more excess able. If anyone has more helpful tips, I'm all ears!
902066 is offline   Reply With Quote
Old 03-22-2020   #16
32valvZ
32valvZ's Avatar
Waxed and took her for a ride. Stopped at the Holy Cross Abbey for a few quick pics
Old 03-23-2020   #17
gtcollins@maxnet.co.nz
Our country has been put on lockdown for four weeks
Sent from my SM-G973F using ZR-1 Net Registry mobile app
Old 03-23-2020   #18
91z
Virus projects have already begun. Installed new Alpine ILX-W650 stereo over the weekend. Next will start ordering parts for plenum pull to change injectors and wire open or remove secondaries.
91z is offline   Reply With Quote
Old 03-23-2020   #19
Hoping once weather warms up, I can get the ZR up on the Qjacks and start cleaning suspension bits. Maybe check brake pad wear.
BTW, along w porting top end, I tie wrapped my secondaries open. Next step was removing throttle blades altogether, and finally, removed throttle shafts when heads got ported.
Old 03-23-2020   #20
Mystic ZR-1
Mystic ZR-1's Avatar
Hope ya put in a good word for all of us and our situation while you were there?
Mystic ZR-1 is online now   Reply With Quote
