#11 |
#12 |
It's Actually got a hurst short-throw shifter so it does not have a lift ring.
#13 |
![]() Join Date: Apr 2007
When I had Marc install a Hurst shifter on my '93 back in about 1995 (because I hated the lift ring) it seemed to have enough spring pressure when pushing it sideways that I did not feel any further safeguard was necessary. I never missed a 4-5 shift and went into reverse.--Bob
#14 | |
![]() ![]() Join Date: Nov 2007
However, Ami's Hurst shifter is way more positive that stock. I have accidentally done a 2-5 ![]()
#15 | |
![]() go there.--Bob
2016 Long Beach Red Z06 #10281 "POPS Z" 1995 Polo Green #409 "WARP TEN"--Haibeck 350/510 package, 4.10s, Hurst, Stock Exhaust with QTP Cutouts --Sold but still running strong 1993 Quasar Blue #161 "HIL KING" --Sold but still running strong, now with more than 120,000 miles 1967 Marlboro Maroon/Saddle Corvette Coupe 300 hp/4-spd --Sold a long time ago ZR-1 Net Registry Founding Member #95 NCM Lifetime Member Favorite Quote--Attributed to Mickey Thompson: "Too Much Horsepower is Almost Enough" Last edited by WARP TEN; 02-24-2020 at 12:23 PM. |
#16 |
![]() Join Date: Jan 2006
Old thread..but does anyone have step by step procedures and pictures on swapping the guide tube (and related parts etc) from a black label transmission to a blue label transmission?
#17 | |
I'm running a blue label in my 90', works just fine that way. H ![]()
#18 |
Well, that is the other option. I was trying to prevent issues with getting a new pilot bearing seated just right and hoping to get a good (not China) throw out bearing. I don?t know which is the better way. I am open to suggestions in the best course of action . I know what throw out bearing to use, what pilot bearing do I use if I went that route and what style ? I originally thought swapping the sleeve would be easier and less risky for noise. Anything to swap with fork? Help me make a good decision here. Thanks! I?ll be honest , in all my research I didn?t not catch the guide sleeve until I COMPLETELY installed the blue tag to completion and mean hydraulics hooked up and bleed , c beam in...done. I luckily have not started the engine , I found this by accident as I was researching early model 90 Voss sensors and found one small thread mentioning the tube... oh well, a blessing if I look at it right because I caught it before it was started. I can?t sleep now thinking of redoing the job again on my back on jack stands without a proper trans jack! I researched the swap extensively, maybe it would make a good solutions sticky?
Corvette95 Registry and Forum (*************) 1989 C4 Conv Wht/Gry Auto Hardtop Top Flight SOLD 1995 C4 Coupe Purple/Blk 6 Speed 1989 C4 Conv Wht/Red Auto SOLD 1996 C4 Conv Black/Tan Auto SOLD 1994 C4 Coupe Wht/Blk SOLD 1995 C4 ZR-1 White/Gry #278 Dual Dunn Head SOLD 1986 C4 Coupe Black/Red 4+3 SOLD 1990 C4 ZR-1 Red/Red #0454 Last edited by Corvette95; 12-30-2020 at 12:13 AM. |
#19 |
Yeah that would not have worked. Don't drive the car that way. It would destroy the clutch assembly and probably the input shaft in short order. Switching the Throwout bearing is the only thing you have to do because of the smaller diameter input shaft on the blue label. Everything else is the same, fork included.
I'm sure someone here might have a TO bearing stashed. Your old one could even be traded or sold. The rarely go bad. Put up an ad. If I'm not mistaken the Centerforce TO bearing is made in Brazil not China. While not the same quality as the originals I believe it's serviceable for a stock HP engine. Here's one advertised on EBay. https://www.ebay.com/itm/224102665349 Good thing you caught that. Oh and don't sweat the pilot bearing install. It's a simple install, it rests against a machined stop in the end of the crankshaft. The only thing you can really do wrong is not put it in deep enough. If your concerned simply measure the depth of the old one before you remove it and install the new one to the same depth. H ![]()
90'ZR-1 #1461 Red/Black Ported Intake, Degreed Cams, OBX Headers & Exhaust, Fidanza FW, Secondary Delete, Custom tune, C6 GS Wheels. Sold 08 C6 Z51 Crystal Red Metallic Sold Vararam Intake, Tune, Sold 05 C6 Z51 Red/Black Sold 90'ZR-1 #1723 Black/Gray Sold but not forgotten 91' Z51 L98 White Vert. My First, you always remember your first. Sold. Last edited by Ccmano; 12-30-2020 at 12:42 PM. |
#20 | |
