#11 | |
H ![]()
#12 |
![]() Join Date: Aug 2004
Ccmano thanks for the pic. The gasket you are using is a Jerry's? Works fine with a ported plenum and injector housing I take it?
91 Turquoise Metallic Haibeck 525 #0134 |
#13 | |
H ![]()
#14 | |
I always get two sets just in case ![]() You can see the TB Coolant Port in the gaskets and if you reverse the gaskets front to back you will essentially eliminate TB Coolant. You will still have the hassle of having to remove coolant with each Plenum removal unless you actually place a pipe plug in the Injector housing TB port. ![]() ![]() See this link for TB Coolant Blocking drilling and threading details Injector Housing TB Coolant Blocking Some tips on Coolant Air Lock in the TB Coolant Blocking link also ![]() Ccmano (Hans) has his TB Coolant Blocked also and for him you can insert the gasket front to back or back to front as you like exactly like he suggested with no sealers of any kind on the gasket (especially if you have TB Coolant Blocked).
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-23-2019 at 02:22 AM. |
#15 |
Great thanks for the info. I wonder if Marc blocked it. It has the TB bypass already. Will find out when I replace the gaskets.
#16 |
Yep,I’m a member of the bent pin club.
