Old 12-07-2019   #11
whale
Default Re: Vaccum solenoid switch
So there is a filter that goes on the 3rd port. That means there are only 2 vacuum ports or hoses that are used.
whale is offline   Reply With Quote
Old 12-07-2019   #12
I believe the filter goes on the silver nipple. In the picture the switch on the top is the early design,if you look on the switch you can see the small retainer for the flat filter. Can’t answer the questions a punt the port but my guess is one line in,one line out.
Old 03-29-2020   #13
Corvette95
Corvette95's Avatar
Maybe four Solenoid Valves?
Vacuum Solenoid for early (90' under Plenum).
Vacuum Solenoid (filter) for Later (95' under Plenum)................Solenoid for Charcoal Canister (91'-95' under Plenum).
Solenoid located on Charcoal Canister (not shown) under Drivers Headlight (90').
Is the later 91+ adaptable to work on a 90 or is the 90 solenoid still available? Was going to replace it for maintenance purposes.
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 03-30-2020   #14
Young1
Young1's Avatar
Either will work. Later ones has a round filter earlier ones a flat filter. Put a new one in while you have the plenum off.
ACDelco 214-358 GM Original Equipment EGR Vacuum Regulator Solenoid Valve
$18.36 Prime FREE Delivery
Order it from Amazon.
Originals no longer available. Same valve. Different mount. You can swap out the mounts or cut each off and bolt together. I have done it both ways.
Steve Young
Second Owner
SOLD
SOLD
Old 03-31-2020   #15
Corvette95
Corvette95's Avatar
Do you know the early (90) part # , I know it is discontinued.
Old 03-31-2020   #16
G8nightman
G8nightman's Avatar
I have noticed the new ones not holding vacuum pressure did you test the new ones any issues?
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
G8nightman is offline   Reply With Quote
Old 03-31-2020   #17
Agree. I ordered about 20 of them a couple of years ago and not a single one passed vacuum test. I disassembled one. If I recall correctly, the plunger seal looked like a piece of cardboard. I was planning to try to cut a piece of soft rubber to replace it.
Old 03-31-2020   #18
Young1
Young1's Avatar
I installed one 3 years ago for myself and another 6 months ago for another car. Maybe I got lucky?
Steve Young
Second Owner
SOLD
SOLD
Old 03-31-2020   #19
G8nightman
G8nightman's Avatar
I ended up buying a used one that passed vacuum test
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
Old 03-31-2020   #20
The SPT system doesn't require 100%, leak free vacuum. It can withstand slow leakdown better if both check valves and the vacuum pump are working properly.
Did you vacuum test the valve prior to installation? The ones I tested weren't a total bust but they weren't serviceable in my opinion.
