Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 NCRS for ZR-1s
Old 02-04-2020   #11
Mystic ZR-1
Mystic ZR-1's Avatar
Default Re: 1991 ZR-1 Owners need Help
Originally Posted by dandt67 View Post
Joel
Believe the slightly worn labels that were on my stock 1991 wheels were original to the car. I applied new labels in the same position as the original ones. They are on the flat part of the rim, forty five degrees counterclockwise from the valve stem on all four wheels. Have highlighted center position of the label with a blue piece of tape. Photo attached.
Car is 1470.
Hope this helps
Dan
90 degrees?
Old 02-04-2020   #12
dandt67
Yes 90 degrees. Good catch, my error.
dandt67
1991 ZR-1 Quasar Blue #1470
2016 Z06/Z07 Long Beach Red Tintcoat
dandt67 is offline   Reply With Quote
Old 02-06-2020   #13
Joelbbvette
Joelbbvette's Avatar
90 degrees?
Found the photo and these are the second design that are parallel to the road. I do believe these labels are still available from one of the large Corvette houses.
Thanks
Joel
Joel
Tampa/Rockledge, FL
Present Collection
1969 350/300 AC Convertible
1972 454 Coupe 2nd Owner
1988 KOH EX5006 - ZR-1 Prototype
1990 ZR-1 #277 NCRS Dave McLellan Award 2019
1994 Copper Convertible NCRS Dave Hill Award 2012
2001 Z06 122k miles
Joelbbvette is offline   Reply With Quote
Old 02-07-2020   #14
HIZNHRZ
Joel
Believe the slightly worn labels that were on my stock 1991 wheels were original to the car...
Car is 1470.
My original wheels were the same as dandt67's. My car is VIN 0864.
1991 Blk/Blk #864
Founding Member #255
Marc Haibeck Follower !
Old 02-09-2020   #15
mrand
#1334 is the same as #1470 pictured above: sticker on the flat part of the rim, approximately 9.5" counter-clockwise around the circumference of flat part from the valve stem. It has the two sticker part numbers I mentioned above for front and rear.
I bought the car in 1996 and it had under 40k miles on it as I recall. I haven't replaced the stickers, and have no reason to believe the previous owner would have.
Marc Randolph
1991 #1334 Blk/Gray
mrand is offline   Reply With Quote
Old 08-16-2020   #16
Vettemann98
Vettemann98's Avatar
Originally Posted by DRM500RUBYZR-1 View Post
I have never seen them differently.
Marty
Vettemann98 is offline   Reply With Quote
Old 08-16-2020   #17
ram_g
1991 #1148 here and same as #1470 pictured. (Not sure if the OP is still tracking this, I just saw the thread.)
ram_g is offline   Reply With Quote
Old 08-18-2020   #18
Joelbbvette
Yes I still look at this occasionally. I have managed to order some of the later design (waiting to get them) and if enough interest could get those made also. Would probably be in the range of $55-60 per set of 4 shipped, less than when the larger Parts house was selling them.
Joel
Joel
Tampa/Rockledge, FL
Present Collection
2001 Z06 122k miles
Old 08-22-2020   #19
jrd1990zr1
jrd1990zr1's Avatar
I have a small supply of the curved stickers for the 1990's and now it sounds like the early 1991's only
1968 convertible Lemans Blue,
1986 coupe Medium Blue NCRS Top Flight (sold),
1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold),
1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018,
2003 Anniversary Red Convertible (sold)
Old 08-29-2020   #20
viper107
viper107's Avatar
Where do I get later model ones?
95 admiral blue z(sold)/ / 93 ruby z(sold) 91 steel blue z/95 aqua z haibeck 510, 91 callaway 415 areobody #5
viper107 is offline   Reply With Quote
