Old 08-13-2019   #11
PhillipsLT5
PhillipsLT5's Avatar
Default Re: New Owner New Problems- Don't know where to start
I would use amsoil 10-40, See ZR-1 specialist, articles
Old 08-13-2019   #12
32valvZ
32valvZ's Avatar
Originally Posted by Karl View Post
The ZR-1 sucks down oil and your best bet is to properly install a oil catch can.
I believe most of the carbon buildup happens because of the oil usage.
I am on my second Z and both have had a catch can and both catch lots of oil.
Where did you get the catch can? I had one on each of my 02 Z06/LS6 cars, but I hadnt seen one for the LT-5.
Thanks, John
[B]1990 #2815[/B]
Ported Plenum & IH (by Pete)
Haibeck Chip
Rebuilt FPR (by Phil)
FIC Injectors
Watson LT Headers
3" Stainless Works exhaust
Lingenfelter Open Air Lid
Bill B Built Transmission
Shifter & C Beam Plates
[B]SOLD[/B]
Old 08-13-2019   #13
Thanks, John
Local speed shop: Moroso.
Thise pix I took immediately after installing it. After, I dressed it all up nice n neet!
I mounted it to the front of the left fender w/ a bracket I fab'ed up using some aluminum strap fm ACE H/W.
WORKS GOOD!!! Near ZERO coking on the valves (secondaries are full time, also).
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 08-13-2019   #14
32valvZ
32valvZ's Avatar
Thanks Paul.
[B]1990 #2815[/B]
Haibeck Chip
FIC Injectors
Watson LT Headers
[B]SOLD[/B]
Old 08-13-2019   #15
Karl
Karl's Avatar
Thanks, John
Like Paul pointed out any good catch can will work. I have mine mounted on the frame, low behind the driver front wheel.
I got a catch can off eBay and modified it.
I am considering using this one instead.
https://www.ebay.com/itm/2-Port-Oil-...UAAOSw-K1csTz9
1993 ZR-1 #211 Yellow On Beige Beast #2
1992 ZR-1 #427 Black On Black *Sold*
1985 L98 Blue On Blue *Sold*
Old 08-13-2019   #16
billschroeder5842
billschroeder5842's Avatar
Congrats on your ZR1! you will love this car like no other.
Sorry about the hood. Once you get it open, consider the following mod as a "plan B" if you latch ever breaks again:
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
Old 08-13-2019   #17
Thanks, John
Post 148 - Elite Engineering Oil Catch Can
Post 242 - Installation of Elite Oil Catch Can and Allen Head Oil Pan Drain Plug
Old 08-13-2019   #18
Karl,
Let me know how u like it. I modified mine based on ur suggestions. Have u found urs to be inadequate?
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 08-14-2019   #19
Karl
Karl's Avatar
Karl,
The only area of improvement I can see is doing a better job of filtering out water and fuel vapors.
The catch can in the link above has a 50 micron bronze filter. Only downside is it has to be cleaned.
The one I have now I just have to dump the oil and I am done.
I think I need to replace the a/c compressor on my car so I may have the plenum off soon to see if any oil is making it into the plenum.
Old 08-14-2019   #20
32valvZ
32valvZ's Avatar
The braided lines look great, but is there a reason regular hose cant be used?
[B]1990 #2815[/B]
Haibeck Chip
FIC Injectors
Watson LT Headers
[B]SOLD[/B]
