Old 07-06-2019   #11
Default Re: Can't get into gear...
When I first got my '93 in 1994, on a Friday afternoon I took a business trip to Indiana from Chicago across the notorious I-80/94 interstate then down I-65. I started losing my clutch the same way, pedal catching progressively closer and closer to the floor, and it eventually got to the point that I was driving without a clutch. I really didn't want to drive back on the usually horrible Friday afternoon I-80/94 traffic without a properly working clutch, so just by luck I found a small rural Chevrolet dealer just before they closed at 4 PM. They fairly quickly diagnosed the problem as lack of clutch fluid (a slow leak). They fixed it quickly by refiling it for me, and didn't even charge me for it. They were so excited to see a ZR-1--they had never had one at their dealership--that they were happy to do the work for free. Got home safely, then a few days later got a new master and slave cylinder just to be sure. Never a problem after that in 70,000 miles of driving. --Bob
Old 07-06-2019   #12
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
What they all said!
Don't kill the cap when you tighten it.
Try not to overfill, clutch fluid, like brake fluid, could be used as paint remover.
First time I wrestled with that cap, was sure I was going to break the reservoir off of the base, but I didn't, nor should you.
Rarely have I had to bleed it, just depends how low it becomes, but working the pedal 20-30 times always restored my pedal even when near dead to the floor.
Marty
Old 07-07-2019   #13
jpalmer1717
Well thank you everyone! This site is such an awesome resource.
jpalmer1717 is offline   Reply With Quote
Old 07-07-2019   #14
For future reference, you can join the Registry and access the Heart Of The Beast (on-line) magazine. #46 contains the complete procedure for replacing and bleeding the clutch hydraulics, should you ever need to. OR, PM me with your email address and I can send you a copy.
Welcome to the club!
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
