Old 07-04-2019   #11
secondchance
Default Re: Cooling system expansion tank question
Originally Posted by Wigert View Post
I have already replaced the main thermostat but isnt there a thermostat in the cap? Looks like it but maybe I am mistaken...
Sent from my EVR-L29 using ZR-1 Net Registry mobile app
There is no thermostat in the radiator cap. It's spring loaded set to release pressure at predetermined pressure. Caps for Corvettes of the era was 14-15 psi.
Old 07-04-2019   #12
Wigert
My mistake, I very much appreciate you clearing that out. Okay so it's only a spring for pressure release.
If the engine is hot and running, should I in that case see a higher coolant level in the expansion reservoir up front at idle? If it has not leaked out elsewhere...
Wigert is offline   Reply With Quote
Old 07-04-2019   #13
secondchance
My guess is, if the overflow tank level is at its highest when the motor is at operating temp and at high rpm.
