Old 07-08-2019   #11
conesare2seconds
Default Re: help with brake light switch
Thanks for the helpful responses. I’ll get back under the dash and have another go at it.
Old 07-09-2019   #12
conesare2seconds
Well, in a victory more for luck and not giving up too easily than for my electrical expertise, we now have full brake lights. I checked out the FSM (spot on references, thanks again) and fiddled with the connectors as suggested. What made the difference? No idea, but take the victories you get. Appreciate everyone’s input.
Old 07-10-2019   #13
WVZR-1
I'd think the 11 terminal to the directional was only loose. The 'latching' is centered and frequently it's not latched by many. I'd not worry and if you've a similar situation ever > GO THERE FIRST!!
Have you ever done a directional switch, column repairs or had the column removed for any reason.
Old 07-10-2019   #14
conesare2seconds
No known history of directional switch or column repair/removal. The microfueler is wired in nearby and the ALDL relocated, so the wiring in this vicinity has been “touched”, perhaps the source of the loose contact.
