Old 06-09-2019   #11
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Coolant Vent Line Alternative
First start on Friday
Cam chains and lifters are pretty noisy until oil pressure builds up which is normal.
https://youtu.be/4qnjCDJMGks
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 06-09-2019   #12
Ccmano
Ccmano's Avatar
Don’t you hate that, especially since it takes 2-3 minutes to fully resolve.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 06-09-2019   #13
Young1
Young1's Avatar
Congratulations it is alive and ready for tuning and regular tire changes.
Steve Young
Second Owner
SOLD
SOLD
Old 06-09-2019   #14
gtcollins@maxnet.co.nz
Awesome and I like coolant vents
Sent from my SM-G960F using ZR-1 Net Registry mobile app
Old 07-20-2019   #15
In the final stages of installing the 427. Decided to run the engine coolant vent lines under the plenum in 5/16 SS tubing. More secure than running it in hose.
Attachment 9706
Just was thinking about this today.. What size fittings did you use with the 5/16" line?
What did you use to bend the lines?
Since I still have secondaries, I am thinking off adding these on the coolant tubes as I am not sure I have room for them under the plenum.. Espcially with my LS2 coils
Old 07-20-2019   #16
Jagdpanzer
Jagdpanzer's Avatar
1/8 “ NPT 90 degree fittings in the injector housings.
Simple hand tubing bender from the local tool store.
https://images.app.goo.gl/eU4B7tq6y5p2d5UE8
I basically had the same setup on my stock motor run in 5/16” hose which still had secondarys.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 07-20-2019   #17
Jagdpanzer
Jagdpanzer's Avatar
I picked up 5/16” tubing and fittings from McMaster Carr
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 07-21-2019   #18
longhorns05
longhorns05's Avatar
Great work! Who built the engine?
93 ZR-1 Red/Red 415ci
Jeal cams/headers, hf cats, B&B
Wilwood brakes, DRM coilovers
94 ZR-1 Red/Blk 368ci
SW headers, hf cats, Corsa
16 GT-R Blk/Blk Stg1 3.8
BL1200X, Shep1k, Motec
1250 whp on pump e85
longhorns05 is offline   Reply With Quote
Old 07-22-2019   #19
Jagdpanzer
Jagdpanzer's Avatar
Had a shop in Chicago do the 4.125” closed deck cylinder liners and local motor machine shop do the balancing and valve seat work. And I did the rest.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 07-25-2019   #20
longhorns05
Very nice, best of luck with it
