Old 05-24-2019   #11
ALLTHECAMS
ALLTHECAMS's Avatar
Default Re: New dyno results!
Originally Posted by indy91zr1 View Post
Did you just port intake manifold and injector housings or heads also? Been looking at doing this as of lately as I am getting unamused with the power level it is at.
I port matched the heads.
Sent from my XT1710-02 using Tapatalk
ALLTHECAMS is offline   Reply With Quote
Old 05-24-2019   #12
ALLTHECAMS
ALLTHECAMS's Avatar
Link to the video. At the end it shows 414 rwhp but that was a false reading from hitting the limiter.
https://youtu.be/Ss69L6oS2bI
Old 05-24-2019   #13
Karl
Karl's Avatar
Car sounds great! Which exhaust do you have and are those 18" wheels?
Old 05-24-2019   #14
EvanZR1
EvanZR1's Avatar
Nice! Love you Shelby wheels, have those myself. Paint job on the engine looks great!
EvanZR1 is offline   Reply With Quote
Old 05-24-2019   #15
ALLTHECAMS
ALLTHECAMS's Avatar
Borla Challenge exhaust and yes they are Shelby Series 1 18" wheels.
Old 05-24-2019   #16
Regimof3
Saw this bad dad today. Really good looking car. The white plenum and valve covers is brilliant touch.
Regimof3 is offline   Reply With Quote
Old 05-26-2019   #17
tiegsd
tiegsd's Avatar
1990 Black/Black ZR-1 #1155
1993 White/Red coupe (Regrettably sold)
tiegsd is offline   Reply With Quote
Old 05-27-2019   #18
ALLTHECAMS
ALLTHECAMS's Avatar
Thanks Reggie! You've got a real nice Z too! Great meeting you.
Matt
Old 05-30-2019   #19
Top Toy
Top Toy's Avatar
Nice improvement but you're running dangerously lean in the upper RPM range if your AFR graph is correct. Suggest you add fuel to get it into the 12.5 to 12.8 range.
Sent from my HTC U11 using ZR-1 Net Registry mobile app
'95 ZR-1, aqua/gray, #167
368 LPE/Haibeck, Web cams, Stainless Works headers, B&B Fusion exhaust, 18" Fikse wheels, Alcon brakes, lowered. 491 SAE RWHP.
Top Toy is offline   Reply With Quote
Old 05-30-2019   #20
I would not characterize the AFR in the upper rpm range as dangerously lean.
13-13.1 I believe is fine. Frankly, I would lean out that “sag” in the mid range and probably take out a bit of AE in the upper part of the AE table. I would try a bit more fuel in the top end just to see which way the power goes as a trial.
What was the SA for these run? Did u check for knock?
