#11 |
![]() Join Date: Sep 2008
An Important Tip:
When entering or exiting the vehicle DO NOT grab the steering wheel! The wheel has a universal joint to permit the up and down tilt functions. It was not designed for lateral stress, and if done repeatedly, you will begin to notice that the wheel begins to move from side to side, and the u joint will eventually fail. While repairable, it takes time, and therefore may become an expensive repair. Instead of grabbing the wheel, grab the A post (windshield pillar) instead. It actually provides better leverage, and there is nothing that can be easily broken. I also while using the A post, jam my left shoulder/arm into the rear door jamb area and push forward with my upper arm while holding the a post with my right. It also helps to have the rear part of the bottom seat raised when getting in or out. I rarely have a problem getting in or out EXCEPT if the door cannot be fully opened, which then limits swinging your leg and foot in. Good luck to all with their "replacements". Marty |
#12 |
![]() Join Date: May 2018
Great posts full of advice and insights based on practical, hands on applications.
Hard to beat a "seasoned professional" in the real world!!! Thanks to all |
#13 |
![]() Join Date: Mar 2004
You old guy's have a lot of problems.
#14 |
![]() Join Date: Feb 2013
I have had both knees replaced. I do likewise using the A pillar with left hand, right foot in, swing butt in using right hand on upper right bolster and plop😆😆. Never use the steering column or console door.
Jim 1990 Z # 2441 1959 c-1 230 HP 4 speed frost blue/silver 3 owner 2011 cts-v 556 HP, manual 6 speed 1955 chev 2dr ht PP 265 3 speed w/OD |
#15 |
![]() Join Date: Nov 2007
Well, I have two things going for me (I hope):
First: Back when I bought my Z in 2007, the first mod was to get rid of the sport seats and replaced them with standard seats out of a 95 C4. Best mod I ever did - far as comfort/drivability goes!! Second: This hip crap hid me suddenly just 2 years ago: hit me like a hammer. So, I've been sitting and spinning (or dragging) my legs in for 2 years now. Got that maneuver down purdy good! But, really... getting rid of those hideous "sport seats" was the best thing I ever did, far as enjoyment of the car goes. |
#16 |
![]() Join Date: May 2010
Best wishes for a full recovery. I don’t know my input will help, but since I replaced my steering wheel with a quick release aftermarket wheel it is much easier to get in and out. Since there is no steering wheel in the way it just seem so for me. I don’t have bad hips and only bad knees. I also won’t ever be able to use or lean on the steering wheel to mess that up. My 90Z column had the messed up joint mention from previous owners using it to get in/out I assume.
Having said this, most folks won’t want to remove the air bag. Me, I fear that damn thing more and take my chances figuring if I had my old 68 Camaro Z/28 I would be driving around without an air bag anyway. Sent from my iPhone using ZR-1 Net Registry
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() Last edited by HAWAIIZR-1; 05-22-2019 at 08:30 AM. |
#17 |
![]() Join Date: Jun 2015
Hips are ok but, 4 abdominal surgeries has taken their toll. I do the "sit and spin" as Paul puts it.
#18 |
The D shaped wheel also helps when tilted full up.
