#11 |
![]() Join Date: Apr 2017
I use Mobil 1 oil
[SIGPIC][/SIGPIC] 91-#1935 Black/black & gray, Haibeck 500 Cams by Pete |
#12 |
That tensioner from Jerry's looks promising. How much work is required to replace it? My back won't allow me to do much now-a-days, so I would have to pay to have it replaced.
#13 | |
![]() Join Date: Jan 2006
Assuming it’s only/mostly oil pressure related: I’d wait on the oil filter. It’ll cure some. One of my cars (non-Dunn) has the tensioner upgrade & good filter but still rattles some until oil pressure builds. Ted |
#14 |
I'm not far from Mark Haibeck.
#15 |
#16 |
I have a short video of a startup, but I can't figure out how to post it.
#17 | |
Mark Haibeck does an excellent job of explaining the situation. http://www.zr1specialist.com/HAT%20W...e%20Rattle.pdf H ![]() Last edited by Ccmano; 05-07-2019 at 09:54 PM. |
#18 | |
#19 | ||
![]() Join Date: Jun 2013
"Oil Filter Recommendation Update 2011 Recently we have observed that the anti-drain back valve in the Bosch 3401 filter is leaking. The filter looses most of the oil after the engine is off for 24 hours. This causes an approximately one second delay before the oil pressure builds at startup. This can add to the time that the right side camshaft chain rattle occurs. My current recommendation is for the ACDelco PF970C filter. We have found that it retains eight ounces of oil after the engine is off for 24 hours. Although the part number has a “C” in it like the original ZR-1 filter the color of the filter is blue. We also found that the NAPA 1324 filter retains eight ounces of oil after the engine is off for 24 hours. The filter is white in color and is made by WIX." Marc also had an update about some Bosch filters leaking down: http://www.zr1specialist.com/HAT%20W...ate%202015.pdf |
#20 |
![]() Join Date: Nov 2007
Expertise: I suggest you buzz over to Marc's shop or Pete's shop. Let either of them listen to it and diagnose it...is what I have done once or twice.
