05-06-2019 | #11 |
Re: Lean at high rpm
I would agree w Hans. Dyno ing the car makes no sense until u have the fuel issue resolved. The shop should be able to email u the run file.
05-06-2019 | #12 | |
Sent from my XT1710-02 using Tapatalk
1991 ZR-1 #520 Arctic White/Gray |
05-06-2019 | #13 |
Yes I understand that altho checking FP ahead of the dyno would have also made u aware of it. What I meant is that going forward dyno would not make sense.
05-06-2019 | #14 | |
05-07-2019 | #15 |
Tested the pumps at the test plug by the ECM. Read 7 amps.IMG_20190507_180202169.jpg
05-07-2019 | #16 | |
H
05-07-2019 | #17 | |
05-07-2019 | #18 | |
H
05-07-2019 | #19 | |
Matt Sent from my XT1710-02 using Tapatalk
05-08-2019 | #20 |
After blowing up the AF graph, I noticed it looks a little like my initial dyno pulls, i.e., trends up with RPM, and looks like the operator cut it off just shy of 7000 rpm - prolly cuz AF was going lean?
Here are the graphs of my stock 90 Z, taken back in 2007. The leaning you see was due to deteriorating OEM injectors in the presence of alcohol doped fuel; a fact born out by reading the resistance across each injector, AFTER the motor was fully warmed up. (I'll post the procedure for measuring the injectors w/ o removing the plenum...if/when I can find the diagram I made!) My 1990 LT5 base case with defective OEM injectors
