04-26-2019 | #11 |
Re: WTB crank sensor connextor
Could this be it?
https://www.aliexpress.com/item/10se...810187129.html |
04-26-2019 | #12 |
04-26-2019 | #13 |
Guys - very important when shopping connectors GM/Delphi etc ID connectors according to 'terminal' usage NOT the shell. I've never seen 'wire to wire' 150.2 (pull to seat).
The 'male' connector shell spork2367 mentions would do a MP150. I'm not sure that a MP150.2 and a MP150 share dimensions BUT I might doubt. ***Actually Jerry uses a MP150.2 part # but the connector in his image is actually a MP150. The OE is/was a 150.2 pull to seat I'm quite confident. If you have the 150.2 mating compare it to the dimensions for the 12129615 mentioned. You can compare using the NEWER APTIV(used to be DELPHI) catalog. I've used the 8A-202 section of GM FSM to create wiring using this catalog for years. This catalog will ID all seals, terminals plugs used with that particular connector/shell. If the terminals are on 6mm centers on the 150.2 I'd think all is well. *** terminals on a 150.2 'pull to seat' I believe are 3.5mm spacing so I don't believe a MP150 will do -=Jeff=- doing 'wire to wire' adapting APTIV can be very useful. Just enter the 12129615 and GO ..................................... APTIV ....eCAT https://ecat.aptiv.com Last edited by WVZR-1; 04-26-2019 at 05:36 PM. |
04-26-2019 | #14 | |
Good to hear from you! Lacking detailed knowledge, I do what I can - attempt to match visually. I have enough useless connectors in my drawers for sure! Below is what popped up when I tried 12129615. https://www.lawsonproducts.com/Metri...ing/1446745.lp |
04-26-2019 | #15 | |
You did something wrong - this direct link should work. Look in documents and related areas when catalog populates. Get out your FSM and experiment using the 8A-202 section. *** I don't know how long this 'direct link' might remain active. https://ecat.aptiv.com/feature?search=12129615 Last edited by WVZR-1; 04-26-2019 at 11:10 AM. |
04-26-2019 | #16 | |
I don't believe the series you're looking for is the 150.2, I believe it is the 150. Here is the female I posted the link to next to the mating male which is identical to the connector Jerry lists. |
04-26-2019 | #17 | |
The GM# 12167116 (PT782) is from the GM SPO catalogs. That is 'pull to seat'. These are from a '95 FSM. I don't believe the earlier years display these in 8A-202 C2 is originally a 150.2 'pull to seat' LT5 DIS C1.jpg LT5 DIS C2 - 3 -4.jpg It would be difficult/next to impossible to repair a factory harness using a 'pull to seat' shell. Last edited by WVZR-1; 04-26-2019 at 05:39 PM. |
04-26-2019 | #18 |
Thanks for all the help.. I found it..
Casper Electronics #410016, I ordered a couple, if they work I can eliminate added wiring I put in my car..
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - Borla Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 |
04-26-2019 | #19 | |
Here is a pigtailed set: https://www.ebay.com/itm/Delphi-Metr...81c1%7Ciid%3A1 Last edited by spork2367; 04-26-2019 at 01:33 PM. |
04-26-2019 | #20 | |
