Old 04-27-2019   #11
HAWAIIZR-1's Avatar
Default Re: Car is running Fantastic
Wow Jeff!! I just gotta admire all the smart folks on here like you that take these cars to a new level and come up with options.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 04-27-2019   #12
tpepmeie
I can’t tell exactly... is the factory ICM connected to anything?
Old 04-27-2019   #13
Factory ICM is no longer in the car
Old 04-27-2019   #14
Ccmano
Wow Jeff, outstanding! Do you see this as a one off?
H
Old 04-27-2019   #15
Pete
Pete's Avatar
Very nice work Jeff.
Really like the way you made the coils fit in the valley area.
Great job.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 04-27-2019   #16
H
Hopefully not. I do however have a second unit. (Before anyone asks, I am not looking to sell it at the moment)
I have been in contact with the designer/developer and it sounds like there could be potential that he makes more, I had bought his last two, knowing they might not work.
Great job.
Pete
Thanks Pete, however, unless you remove the tray, it is tough to swap plug wires. The picture I posted shows straight boots, the new set of wires are 90deg boots.
Old 04-27-2019   #17
Jeff,
Do u have pics of the trigger harness for the coils? And did u use the existing power circuit to energize the coils? When I did this conversion, but using the stock ICM, I needed to use a separate circuit to energize the coils given that our stock circuit is only 10A IIRC.
Old 04-27-2019   #18
Jeff,
No I don't have pictures of the harness. I cut the plugs and fuse off of the A.I.R Pump assembly and used those. I repinned one wire of the A.I.R Relay. instead of going to the ECM that controlled it, I ran a new wire to ground.
So I used a relay to power the coils with a 15 or 20A fuse.. yeah the wires run to the front of the car, but the circuit was already there and no longer used since I removed the A.I.R. pump.
Old 04-27-2019   #19
Karl
Karl's Avatar
Looking good can't wait to see it in person!
Old 04-27-2019   #20
Jeff,
Is dwell configurable? LSx coils throw a hotter spark and part of that is w 8 coils they can dwell longer. I’m assuming u re-gapped plugs.
