Old 04-24-2019   #11
dredgeguy
dredgeguy's Avatar
Default Re: Alternator upgrade
When Marc did the alternator upgrade on my car to 200 amp he also did the double wire to the AC blower. Before the mod air flow out my vent was at 10 mph and after it was 14 mph. I like it very much. Just spent 3 hours in Dhaka, Bangladesh traffic with no AC and can't wait to get home next week!
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 04-24-2019   #12
secondchance
Hey Charlie! I added additional 18 ga. wire from the battery to the HVAC controller and fan's performance improved a lot also.
Old 04-24-2019   #13
ghlkal
ghlkal's Avatar
Additional 8 ga. cable was added between the alternator post to battery to allow for additional current and, while at it, added additional 18 ga. between the battery and HVAC controller resulting in some extra oomph to HVAC fan.
The additional wiring is a great idea. I'll have to remember that.
1990 ZR-1 #2180 Red/Black
Many of the usual mods for 460HP, tuned by Marc Haibeck
ZR-1 Net Registry Member #1548
Old 04-25-2019   #14
I called and Yes we can get a group price.. minimum for the group price will be 5..
I will post a thread with details later..
Old 04-25-2019   #15
HAWAIIZR-1's Avatar
Thanks Jeff!!!
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 04-26-2019   #16
secondchance
Should be able to round up 5 easily.
Tell Kevin I said "hi!".
Old 04-26-2019   #17
what is the benefit of this one vs the CS-144 from Power Master?
Old 04-26-2019   #18
secondchance
Hairpin alternators are suppose to produce higher amp at idle compared to conventional. Also, suppose to perform better at high temperature such as hot day, underhood condition.
Above are based on what I have read. Not been able to confirm so far.
Old 07-26-2019   #19
How is this holding up? been thinking about this again.. I noticed it mainly at idle. I have a couple ideas to try.. before dropping money on one of these.. Group buy never panned out.. nobody was interested. I think if I buy one, the stock power is fine, I just want better idle current
Old 07-26-2019   #20
secondchance
It's holding up fine. Last week in DC area was between 96 to 103 degrees. I never found myself in major traffic back up (a disappointment!) but evening commute meant about 15 minutes of bumper to bumper.
With Spal fans running at full speed, maximum coolant temp I saw was 211. Once it hit 211, temp started to come down and around 200-201 would go up to 208 and repeat. With fans running, voltage readout was 14.3 to 14.5 volts. Oil temp was steady at 197 but occasionally would go up to 201 to 202.
Dewitt dual core, 200 amp alternator and Spal fans definitely reeled in coolant temp concern in worst case scenario.
It would be interesting to compare voltage reading of stock 94 Z with OEM fans running vs. my setup, although not apple to apple.
