03-26-2019 | #11 |
Re: Thank You.......
To confirm that it is in fact the primary pump try pulling the fuse to the secondary pump and see if it will start.
03-26-2019 | #12 |
Thank you again Jagdpanzer, I will try that tomorrow evening and post results
03-28-2019 | #13 |
Anyone know where the fuse is located for the second fuel pump? I looked on the passenger side of the dash and didn’t see anything that was really clear..
03-29-2019 | #14 | |
If my memory serves me correctly, it is actually under the dash on the right passenger side. You will have to remove the kick panel and get under the dash to see it. If you’re a bigger person you might have to remove the seat to get under there. Sent from my iPhone using ZR-1 Net Registry
03-29-2019 | #15 |
Here you go:
https://www.corvetteforum.com/forums...ump-fuses.html Sent from my iPhone using ZR-1 Net Registry
03-30-2019 | #16 |
I have to be an idiot.......I mentioned the secondary pump and I really need the fuse for the primary pump since the car shuts off after being warm. After I got the dash apart I reread my post......ugh!
03-30-2019 | #17 |
If it needs fuel pumps (again) where is the best place to get them?
03-30-2019 | #18 |
Jerry’s Gaskets has this on his site... I’ve use the Preformace Electric pumps from RockAuto.com with good result several times.
H Jerrys Gaskets ZR-1 Corvette LT5 Parts, Gaskets & Seals www.jerrysgaskets.com Unfortunately, new senders w/pumps are no longer available. This leaves us with the only the option to repair the unit. More often than not, it’s only the fuel pumps that have failed. Both pumps are identical and are available from several different manufacturers. GM #25163473 (ACDelco #EP381) (fits suburban w/454 engine) w/o strainer, (Rock Auto) $57.79 BWD #P36 Neihoff #P36 AIrtex #E3240 (E3940) has been reported to have different elec connector Performance Electric #P240KC (Rock Auto) $18.70 GMB #5301042 (Rock Auto) $20.79 Delphi #FE0039 (Rock Auto) #45.99 Carter #P74037 Rock Auto) $24.99 Carter #P74074 (Cross ref to GM #25163473) Rock Auto $33.89 Carter #P74167 Cross ref to GM #25163473) Rock Auto $33.89 Bosch #69225 Rock Auto) $53.79 Denso #951-5016 (exact fit verified) Denso #952-0057 Fuel Pump Strainer only I would recommend the Denso unit, Amazon & WalMart @ $57.04. Does not come with new filter socks
03-31-2019 | #19 |
Thank You.......
Wow awesome! Thanks so much as I will be purchasing Denso units as soon as I can confirm it’s the pump.
Sent from my iPhone using ZR-1 Net Registry Last edited by Rumblin70SS396; 03-31-2019 at 02:04 PM. |
03-31-2019 | #20 |
Found it, looks like a blown fuse Boys......will charge the battery and try and start tomorrow..
